In DS6.2, the deepstream-app app succeeds or fails depending on the enable value (0 or 1) of [sink0]
**• Jetson AGX Xavier Developer Kit
**• DS6.2
**• JetPack 5.1.1
After installing DS6.2 and compiling deepstream-app, when the three files below are executed, the deepstream-app app succeeds or fails depending on the enable value (0 or 1) of [sink0].
→ source4_1080p_dec_infer-resnet_tracker_sgie_tiled_display_int8.txt
→ source30_1080p_dec_infer-resnet_tiled_display_int8.txt
→ source30_1080p_dec_preprocess_infer-resnet_tiled_display_int8.ㅅㅌㅅ
[sink0]
enable=0 <------
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
If [sink0] is set to enable=0, the app works normally.
@ubuntu:~/ds62/sources/apps/sample_apps/deepstream-app$ ./deepstream-app -c …/…/…/…/samples/configs/deepstream-app/source30_1080p_dec_infer-resnet_tiled_display_int8.txt
*** DeepStream: Launched RTSP Streaming at rtsp://localhost:8554/ds-test ***
Opening in BLOCKING MODE
0:00:02.461542272 7701 0xaaaaf5eb3960 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::deserializeEngineAndBackend() <nvdsinfer_context_impl.cpp:1909> [UID = 1]: deserialized trt engine from :/home/robopia/ds62/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
INFO: [Implicit Engine Info]: layers num: 3
0 INPUT kFLOAT input_1 3x368x640
1 OUTPUT kFLOAT conv2d_bbox 16x23x40
2 OUTPUT kFLOAT conv2d_cov/Sigmoid 4x23x40
0:00:02.509025984 7701 0xaaaaf5eb3960 INFO nvinfer gstnvinfer.cpp:680:gst_nvinfer_logger:<primary_gie> NvDsInferContext[UID 1]: Info from NvDsInferContextImpl::generateBackendContext() <nvdsinfer_context_impl.cpp:2012> [UID = 1]: Use deserialized engine model: /home/robopia/ds62/samples/configs/deepstream-app/…/…/models/Primary_Detector/resnet10.caffemodel_b30_gpu0_int8.engine
0:00:02.565590848 7701 0xaaaaf5eb3960 INFO nvinfer gstnvinfer_impl.cpp:328:notifyLoadModelStatus:<primary_gie> [UID 1]: Load new model:/home/robopia/ds62/samples/configs/deepstream-app/config_infer_primary.txt sucessfully
Runtime commands:
h: Print this help
q: Quit
    p: Pause
    r: Resume
NOTE: To expand a source in the 2D tiled display and view object details, left-click on the source.
To go back to the tiled display, right-click anywhere on the window.
** INFO: <bus_callback:239>: Pipeline ready
NvMMLiteOpen : Block : BlockType = 261
NVMEDIA: Reading vendor.tegra.display-size : status: 6
NvMMLiteBlockCreate : Block : BlockType = 261
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
H264: Profile = 66, Level = 0
** INFO: <bus_callback:225>: Pipeline running
NVMEDIA: Need to set EMC bandwidth : 376000
NVMEDIA_ENC: bBlitMode is set to TRUE
**PERF: FPS 0 (Avg) FPS 1 (Avg) FPS 2 (Avg) FPS 3 (Avg) FPS 4 (Avg) FPS 5 (Avg) FPS 6 (Avg) FPS 7 (Avg) FPS 8 (Avg) FPS 9 (Avg) FPS 10 (Avg) FPS 11 (Avg) FPS 12 (Avg) FPS 13 (Avg) FPS 14 (Avg) FPS 15 (Avg) FPS 16 (Avg) FPS 17 (Avg) FPS 18 (Avg) FPS 19 (Avg) FPS 20 (Avg) FPS 21 (Avg) FPS 22 (Avg)FPS 23 (Avg) FPS 24 (Avg) FPS 25 (Avg) FPS 26 (Avg) FPS 27 (Avg) FPS 28 (Avg) FPS 29 (Avg)
**PERF: 18.32 (18.11) 26.96 (26.45) 23.19 (22.82) 26.96 (26.45) 32.73 (31.95) 23.19 (22.82) 23.19 (22.82) 20.90 (20.61) 18.32 (18.11) 19.32 (19.08) 20.90 (20.61) 20.90 (20.61) 20.90 (20.61) 26.96 (26.45) 26.96 (26.45) 32.72 (31.95) 20.90 (20.61) 18.32 (18.11) 20.90 (20.61) 20.90 (20.61) 26.96 (26.45) 23.19 (22.82) 20.90 (20.61) 26.96 (26.45) 19.32 (19.08) 26.96 (26.45) 20.90 (20.61) 23.19 (22.82) 20.90 (20.61) 20.90 (20.61)
**PERF: 32.79 (28.70) 32.79 (31.59) 32.79 (30.61) 32.79 (31.59) 32.59 (32.49) 32.79 (30.61) 32.59 (30.46) 32.59 (29.69) 32.79 (28.70) 32.39 (28.90) 32.59 (29.69) 32.79 (29.84) 32.79 (29.84) 32.79 (31.59) 32.79 (31.59) 32.79 (32.66) 32.79 (29.84) 32.79 (28.70) 32.79 (29.84) 32.79 (29.84) 32.79 (31.59) 32.59 (30.46) 32.39 (29.54) 32.79 (31.59) 32.79 (29.19) 32.79 (31.59) 32.79 (29.84) 32.79 (30.61) 32.59 (29.69) 32.39 (29.54)
q
Quitting
nvstreammux: Successfully handled EOS for source_id=0
nvstreammux: Successfully handled EOS for source_id=1
nvstreammux: Successfully handled EOS for source_id=2
nvstreammux: Successfully handled EOS for source_id=3
nvstreammux: Successfully handled EOS for source_id=4
nvstreammux: Successfully handled EOS for source_id=5
nvstreammux: Successfully handled EOS for source_id=6
nvstreammux: Successfully handled EOS for source_id=7
nvstreammux: Successfully handled EOS for source_id=8
nvstreammux: Successfully handled EOS for source_id=9
nvstreammux: Successfully handled EOS for source_id=10
nvstreammux: Successfully handled EOS for source_id=11
nvstreammux: Successfully handled EOS for source_id=12
nvstreammux: Successfully handled EOS for source_id=13
nvstreammux: Successfully handled EOS for source_id=14
nvstreammux: Successfully handled EOS for source_id=15
nvstreammux: Successfully handled EOS for source_id=16
nvstreammux: Successfully handled EOS for source_id=17
nvstreammux: Successfully handled EOS for source_id=18
nvstreammux: Successfully handled EOS for source_id=19
nvstreammux: Successfully handled EOS for source_id=20
nvstreammux: Successfully handled EOS for source_id=21
nvstreammux: Successfully handled EOS for source_id=22
nvstreammux: Successfully handled EOS for source_id=23
nvstreammux: Successfully handled EOS for source_id=24
nvstreammux: Successfully handled EOS for source_id=25
nvstreammux: Successfully handled EOS for source_id=26
nvstreammux: Successfully handled EOS for source_id=27
nvstreammux: Successfully handled EOS for source_id=28
nvstreammux: Successfully handled EOS for source_id=29
App run successful
[sink0]
enable=1 <------
type=2
sync=1
source-id=0
gpu-id=0
nvbuf-memory-type=0
Setting enable=1 on [sink0] causes the app to fail.
** ERROR: main:716: Failed to set pipeline to PAUSED
Quitting
ERROR from sink_sub_bin_sink1: GStreamer error: state change failed and some element failed to post a proper error message with the reason for the failure.
Debug info: gstbasesink.c(5367): gst_base_sink_change_state (): /GstPipeline:pipeline/GstBin:processing_bin_0/GstBin:sink_bin/GstBin:sink_sub_bin1/GstNv3dSink:sink_sub_bin_sink1:
Failed to start
App run failed
I don’t know what the problem is.
Any help would be appreciated.
  1. Setting enable=1 on [sink0] will use nv3dsink to render, could you share more logs? please do “export GST_DEBUG=6” first to modify Gstreamer’s log level, then run again, you can redirect the logs to a file.
  2. can the simplest sample deepstream-test1 work fine? can you see the rendering video?
  3. if did not care about the rendering, you can set type to 1 or 3 in [sink0], it will not render the output video.
In [sink0], only type=1 operates normally, and all 2,3,4,5 fail. Could you please confirm if the same problem occurs with the Orin module as well?
Video rendering (type=5) is not required, but it is used only during development because the results can be checked quickly during development.
noticing you are using xavier, why need to test orin? on my xivar +ds6.2, deepstream-app with “type=3” works fine, here is the log:
type3.txt (21.5 KB)
could you share your whole log of “type=3”?
We are currently developing a carrier board for Orin. It is because we plan to proceed with the current project with Orin NX when the development is completed soon.
Thanks for sending the logs. I’ll look into the problem and share the logs soon
Sorry for the late reply, Is this still an DeepStream issue to support? Thanks
