I am able to generate the images from custom fbx using below command
./start_data_generation.sh --datadir=$DATA_DIR --samples=$TRAINING_SAMPLES --tests=$TRAINING_TESTS
But the images which are generating are in different size than what I expected.
I want to know how can I configure that setting inside the ./start_data_generation.sh
To configure the image size, update the width and height parameters in the RENDER_CONFIG as you can see in python_samples/syntheticdata/offline_generation/generator.py
