Voltage of SYS_VIN_HV is between 7~20V, to have the best/full performance,what’s the best range of voltage?
As Orin document states, Voltage of SYS_VIN_HV between 7~20V are all fine to Jetson Orin. The best performance consideration should be power consumption. For examplem, Jetson AGX
Orin 64GB supports a MAXN performance mode that can enable up to 60W of performance. And Jetson AGX Orin 32GB supports power modes up to 40W. So please just ensure your power adapter can output required power consumption (Watt = V (voltage) x A (current) )
Thanks,
Thanks for your reply.
