In Orin NX, data can be sent in the CAN loopback mode, but it fails to be sent in the normal mode
orin NX can设置为回环模式,通过cansend 发送数据,candump can0 可以抓到日志,正常模式无法发送数据,candump can0无法抓到日志。
Hi 210076320,
What do you mean about “normal mode”?
Do you connect CAN transceivers in your setup?
Please share the block diagram of your connection.
