In orin, ros node can not read /dev/ttyUSB data occasionally
As the image shows, I has an imu which is connected to orin by usb, and a ros node is used to open and read this /dev/ttyUSB to get imu data. But occasionally, the ros node can not read this /dev/ttyUSB correctly. The error dmesg output log when ros node failed to read is showed below. Can someone have a look at this issue. Thanks a lot.
[55877.813601] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[55877.814100] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[55877.814647] NVRM rmapiAllocWithSecInfo: allocation failed; status: Given class-id not valid [NV_ERR_INVALID_CLASS] (0x00000022)
[55877.814650] NVRM rmapiAllocWithSecInfo: client:0xc1d00028 parent:0xcaf00001 object:0x0 class:0x402c
[55877.815967] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[55877.826009] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[55877.826075] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[55877.826130] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[55877.826190] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[55877.826255] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[55877.826309] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[55877.826361] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[55877.875297] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0xffff:
[55877.901814] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[55877.954214] NVRM nvAssertFailedNoLog: Assertion failed: pLockInfo->state == initialLockState @ rs_server.c:1055
[55877.961632] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[55877.961636] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:295
[55921.706492] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[55984.702179] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[56018.925093] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[56018.925587] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[56018.926155] NVRM rmapiAllocWithSecInfo: allocation failed; status: Given class-id not valid [NV_ERR_INVALID_CLASS] (0x00000022)
[56018.926159] NVRM rmapiAllocWithSecInfo: client:0xc1d00029 parent:0xcaf00001 object:0x0 class:0x402c
[56018.927432] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[56018.937490] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56018.937554] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56018.937628] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56018.937687] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56018.937743] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56018.937795] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56018.937845] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56018.986772] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0xffff:
[56019.013214] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[56019.065178] NVRM nvAssertFailedNoLog: Assertion failed: pLockInfo->state == initialLockState @ rs_server.c:1055
[56019.074952] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[56019.074955] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:295
[56047.717720] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[56110.701333] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[56173.705124] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[56236.704129] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[56299.716212] start_addr=(0x20000), end_addr=(0x40000), buffer_size=(0x20000), smp_number_max=(16384)
[56324.362878] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[56324.363398] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[56324.363997] NVRM rmapiAllocWithSecInfo: allocation failed; status: Given class-id not valid [NV_ERR_INVALID_CLASS] (0x00000022)
[56324.364000] NVRM rmapiAllocWithSecInfo: client:0xc1d0002a parent:0xcaf00001 object:0x0 class:0x402c
[56324.365249] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[56324.375238] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56324.375298] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56324.375352] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56324.375407] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56324.375459] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56324.375512] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56324.375566] NVRM nvAssertFailed: Assertion failed: 0 @ g_mem_mgr_nvoc.h:1190
[56324.424577] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0xffff:
[56324.451055] NVRM rpcRmApiControl_dce: NVRM_RPC_DCE: Failed RM ctrl call result 0x56:
[56324.503233] NVRM nvAssertFailedNoLog: Assertion failed: pLockInfo->state == initialLockState @ rs_server.c:1055
[56324.510663] NVRM gpumgrGetSomeGpu: Failed to retrieve pGpu - Too early call!.
[56324.510667] NVRM nvAssertFailedNoLog: Assertion failed: NV_FALSE @ gpu_mgr.c:295
update dmesg.log
dmesg.log (137.4 KB)
I am not sure if it is hardware or kernel issue or related to ROS at all.
Can you confirm teh Orin devkit work normally to exclude any HW issue first?
