In the moveit_config the moveit_resources_panda is?
from moveit_configs_utils import MoveItConfigsBuilder
moveit_config = (
MoveItConfigsBuilder(“moveit_resources_panda”)
.robot_description(file_path=“config/panda.urdf.xacro”)
.robot_description_kinematics(file_path=“config/kinematics.yaml”)
.planning_pipelines(
pipelines=[“ompl”, “pilz_industrial_motion_planner”],
default_planning_pipeline=“pilz_industrial_motion_planner”,
.to_moveit_configs()
config/panda.urdf.xacro the right path is:moveit_resources/panda_moveit_config/config/panda.urdf.xacro
I do not know how the moveit_resources_panda to use?
when i use my own manipulator how to change the moveit_config?
How to use MoveItConfigBuilder is described in below document.
https://moveit.picknik.ai/main/doc/how_to_guides/moveit_configuration/moveit_configuration_tutorial.html#loading-configuration-parameters-into-launch-files
Usually MoveIt Setup Assistant is used to make the moveit_config for the original robot.
https://moveit.picknik.ai/main/doc/examples/setup_assistant/setup_assistant_tutorial.html
