From the document Jetson_TX1_Generic_Customer_Pinmux_Customer_Release,I know the pin A23(GPIO_EXP0_INT) Customer Usage as GPIO03_PL.01.And I follow the Adaption Guid method calculate the gpio number is 89.
In the L4T version R24.2.1,I can control this pin using the following method:
echo “89”|sudo tee /sys/class/gpio/export
echo “out”|sudo tee /sys/class/gpio/gpio89/direction
echo “1”|sudo tee /sys/class/gpio/gpio89/value
but in the R28.1/R28.2.0 it’s error. I can’t set the gpio direction.The information prompt is: Invalid argument.
For an echo which fails, can you “cat” the same file? E.g., if “echo out” fails to direction, what do you get from “sudo cat /sys/class/gpio/gpio89/direction”?
WayneWWW,
I found in the hardware file tegra210-jetson-cv-base-p2597-2180-a00.dts have the node tca9539_74@74,it used the pin.
but in the R24.2.1 version,it is also used.
I found that the R28.1/R28.2 to R24.2.1 more GPIO_PCA953X_IRQ driver.
R24.2.1 log :
pca953x 1-0074:no regulator found for vcc,Assuming vcc is always powerd
gpio wake21 for gpio89
gpiochip_add: registered GPIOs 1008 to 1023 on device:tca9539
R28.1:
gpiochip_add: registered GPIOs 496 to 511 on device :tca9539
In the R28.1 I commented out the “Interrupts=<TEGRA_GPIO(L, 1), 0X0>;” ,then the gpio is all right.
But I don’t know what will happen to this,Tca9539 chip should be on the development board.
