When I execute the above command, the message printed is as follows:
Setting pipeline to PAUSED ...
Pipeline is live and does not need PREROLL ...
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0: sync = false
Setting pipeline to PLAYING ...
New clock: GstSystemClock
/GstPipeline:pipeline0/GstNvArgusCameraSrc:nvarguscamerasrc0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, format=(string)NV12, framerate=(fraction)20/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, format=(string)NV12, framerate=(fraction)20/1
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, framerate=(fraction)20/1, format=(string)I420
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:src: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, framerate=(fraction)20/1, format=(string)I420
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink.GstProxyPad:proxypad0: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, framerate=(fraction)20/1, format=(string)I420
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0/GstFakeSink:fakesink0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, framerate=(fraction)20/1, format=(string)I420
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0.GstGhostPad:sink: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, framerate=(fraction)20/1, format=(string)I420
/GstPipeline:pipeline0/GstCapsFilter:capsfilter1.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, framerate=(fraction)20/1, format=(string)I420
/GstPipeline:pipeline0/Gstnvvconv:nvvconv0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, format=(string)NV12, framerate=(fraction)20/1
/GstPipeline:pipeline0/GstCapsFilter:capsfilter0.GstPad:sink: caps = video/x-raw(memory:NVMM), width=(int)5496, height=(int)3694, format=(string)NV12, framerate=(fraction)20/1
GST_ARGUS: Creating output stream
CONSUMER: Waiting until producer is connected...
GST_ARGUS: Available Sensor modes :
GST_ARGUS: 5496 x 3694 FR = 20.000000 fps Duration = 50000000 ; Analog Gain range min 1.000000, max 22.500000; Exposure Range min 3000000, max 40000000;
GST_ARGUS: 5496 x 3694 FR = 25.000000 fps Duration = 40000000 ; Analog Gain range min 1.000000, max 22.500000; Exposure Range min 3000000, max 40000000;
GST_ARGUS: 2748 x 1842 FR = 50.000000 fps Duration = 20000000 ; Analog Gain range min 1.000000, max 22.500000; Exposure Range min 1000000, max 20000000;
GST_ARGUS: 1832 x 1234 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.500000; Exposure Range min 3000000, max 16670000;
GST_ARGUS: 3872 x 2174 FR = 59.999999 fps Duration = 16666667 ; Analog Gain range min 1.000000, max 22.500000; Exposure Range min 1000000, max 16670000;
GST_ARGUS: Running with following settings:
Camera index = 1
Camera mode = 1
Output Stream W = 5496 H = 3694
seconds to Run = 0
Frame Rate = 25.000000
GST_ARGUS: Setup Complete, Starting captures for 0 seconds
GST_ARGUS: Starting repeat capture requests.
CONSUMER: Producer has connected; continuing.
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 15, dropped: 0, current: 29.19, average: 29.19
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 28, dropped: 0, current: 25.05, average: 27.11
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 41, dropped: 0, current: 25.09, average: 26.44
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 54, dropped: 0, current: 24.83, average: 26.03
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 67, dropped: 0, current: 25.10, average: 25.85
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 80, dropped: 0, current: 25.04, average: 25.71
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 93, dropped: 0, current: 24.91, average: 25.60
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 106, dropped: 0, current: 25.00, average: 25.52
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 119, dropped: 0, current: 25.05, average: 25.47
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 132, dropped: 0, current: 24.94, average: 25.42
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 145, dropped: 0, current: 24.97, average: 25.38
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 158, dropped: 0, current: 24.99, average: 25.34
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 171, dropped: 0, current: 25.02, average: 25.32
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 184, dropped: 0, current: 24.95, average: 25.29
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 197, dropped: 0, current: 25.10, average: 25.28
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 210, dropped: 0, current: 25.04, average: 25.27
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 223, dropped: 0, current: 25.02, average: 25.25
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 236, dropped: 0, current: 24.93, average: 25.23
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 249, dropped: 0, current: 25.01, average: 25.22
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 262, dropped: 0, current: 25.00, average: 25.21
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 275, dropped: 0, current: 25.04, average: 25.20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 288, dropped: 0, current: 25.06, average: 25.20
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 301, dropped: 0, current: 24.89, average: 25.18
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 314, dropped: 0, current: 24.99, average: 25.17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 327, dropped: 0, current: 24.96, average: 25.17
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 340, dropped: 0, current: 24.95, average: 25.16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 353, dropped: 0, current: 25.16, average: 25.16
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 366, dropped: 0, current: 24.92, average: 25.15
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 379, dropped: 0, current: 25.08, average: 25.15
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 392, dropped: 0, current: 24.99, average: 25.14
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 405, dropped: 0, current: 24.90, average: 25.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 418, dropped: 0, current: 25.04, average: 25.13
/GstPipeline:pipeline0/GstFPSDisplaySink:fpsdisplaysink0: last-message = rendered: 431, dropped: 0, current: 25.04, average: 25.13
^Chandling interrupt.
Interrupt: Stopping pipeline ...
EOS on shutdown enabled -- Forcing EOS on the pipeline
Waiting for EOS...
Got EOS from element "pipeline0".
EOS received - stopping pipeline...
Execution ended after 0:00:18.296177659
Setting pipeline to NULL ...
GST_ARGUS: Cleaning up
CONSUMER: Done Success
GST_ARGUS: Done Success
Freeing pipeline ...
