Hello ShaneCCC:
I am currently using the isx031 camera for the ebd data acquisition test, isx031 output uyvy format. I made the following changes to the vi5_capture_dequeue () function in the vi5_fosp.c file:
static void vi5_capture_dequeue(struct tegra_channel *chan,
struct tegra_channel_buffer *buf)
int err = 0;
int vi_port = 0;
int gang_prev_frame_id = 0;
unsigned long flags;
struct tegra_mc_vi *vi = chan->vi;
struct vb2_v4l2_buffer *vb = &buf->buf;
#if KERNEL_VERSION(5, 4, 0) > LINUX_VERSION_CODE
struct timespec ts;
#else
struct timespec64 ts;
#endif
struct capture_descriptor *descr = NULL;
void* frm_buffer = vb2_plane_vaddr(&(vb->vb2_buf), 0);
pr_info("%s: a. embedded_buffer_size: %d\n", __func__, chan->emb_buf_size);
for (vi_port = 0; vi_port < chan->valid_ports; vi_port++) {
descr = &chan->request[vi_port][buf->capture_descr_index[vi_port]];
if (buf->vb2_state != VB2_BUF_STATE_ACTIVE)
goto rel_buf;
pr_info("%s: b. embedded_buffer_size: %d, vi_port: %d\n", __func__, chan->emb_buf_size, vi_port);
if(frm_buffer != NULL) {
pr_info("%s: copying the embedded data onto the frame buffer\n", __func__);
memcpy(frm_buffer,chan->emb_buf_addr,chan->emb_buf_size);
/* Dequeue a frame and check its capture status */
err = vi_capture_status(chan->tegra_vi_channel[vi_port], CAPTURE_TIMEOUT_MS);
if (err) {
if (err == -ETIMEDOUT) {
dev_err(vi->dev,
"uncorr_err: request timed out after %d ms\n",
} else {
dev_err(vi->dev, "uncorr_err: request err %d\n", err);
goto uncorr_err;
} else if (descr->status.status != CAPTURE_STATUS_SUCCESS) {
if ((descr->status.flags
& CAPTURE_STATUS_FLAG_CHANNEL_IN_ERROR) != 0) {
chan->queue_error = true;
dev_err(vi->dev, "uncorr_err: flags %d, err_data %d\n",
descr->status.flags, descr->status.err_data);
} else {
dev_warn(vi->dev,
"corr_err: discarding frame %d, flags: %d, "
"err_data %d\n",
descr->status.frame_id, descr->status.flags,
#if LINUX_VERSION_CODE < KERNEL_VERSION(5, 4, 0)
buf->vb2_state = VB2_BUF_STATE_REQUEUEING;
#else
buf->vb2_state = VB2_BUF_STATE_ERROR;
#endif
goto done;
} else if (!vi_port) {
gang_prev_frame_id = descr->status.frame_id;
} else if (descr->status.frame_id != gang_prev_frame_id) {
dev_err(vi->dev, "frame_id out of sync: ch2 %d vs ch1 %d\n",
gang_prev_frame_id, descr->status.frame_id);
goto uncorr_err;
pr_info("%s: c. embedded_buffer_size: %d, vi_port: %d\n", __func__, chan->emb_buf_size, vi_port);
spin_lock_irqsave(&chan->capture_state_lock, flags);
if (chan->capture_state != CAPTURE_ERROR) {
chan->capture_reqs_enqueued -= 1;
chan->capture_state = CAPTURE_GOOD;
spin_unlock_irqrestore(&chan->capture_state_lock, flags);
pr_info("%s: d. embedded_buffer_size: %d, vi_port: %d\n", __func__, chan->emb_buf_size, vi_port);
pr_info("%s: e. embedded_buffer_size: %d, vi_port: %d\n", __func__, chan->emb_buf_size, vi_port);
wake_up_interruptible(&chan->start_wait);
/* Read SOF from capture descriptor */
ts = ns_to_timespec((s64)descr->status.sof_timestamp);
#else
ts = ns_to_timespec64((s64)descr->status.sof_timestamp);
#endif
trace_tegra_channel_capture_frame("sof", ts);
#else
trace_tegra_channel_capture_frame("sof", &ts);
#endif
vb->vb2_buf.timestamp = descr->status.sof_timestamp;
buf->vb2_state = VB2_BUF_STATE_DONE;
/* Read EOF from capture descriptor */
ts = ns_to_timespec((s64)descr->status.eof_timestamp);
#else
ts = ns_to_timespec64((s64)descr->status.eof_timestamp);
#endif
trace_tegra_channel_capture_frame("eof", ts);
#else
trace_tegra_channel_capture_frame("eof", &ts);
#endif
done:
goto rel_buf;
uncorr_err:
chan->capture_state = CAPTURE_ERROR;
rel_buf:
vi5_release_buffer(chan, buf);
My current configuration in the device tree is as follows:
mode0 {/*mode SENSOR_MODE_1920X1080_CROP_30FPS*/
mclk_khz = "24000";
num_lanes = "4";
tegra_sinterface = "serial_c";
phy_mode = "DPHY";
discontinuous_clk = "no";
dpcm_enable = "false";
cil_settletime = "0";
lane_polarity = "0";
active_w = "1920";
active_h = "1536";
mode_type = "yuv";
pixel_phase = "uyvy";
csi_pixel_bit_depth = "16";
dynamic_pixel_bit_depth = "16";
readout_orientation = "0";
line_length = "2200";
inherent_gain = "1";
mclk_multiplier = "6.1875";
pix_clk_hz = "216000000";
//serdes_pix_clk_hz = "300000000";
gain_factor = "10";
min_gain_val = "10"; /* dB */
max_gain_val = "300"; /* dB */
step_gain_val = "3"; /* 0.3 */
default_gain = "10";
min_hdr_ratio = "1";
max_hdr_ratio = "1";
framerate_factor = "1000000";
min_framerate = "30000000";
max_framerate = "30000000";
step_framerate = "1";
default_framerate = "30000000";
exposure_factor = "1000000";
min_exp_time = "59"; /*us, 2 lines*/
max_exp_time = "33333";
step_exp_time = "1";
default_exp_time = "33333";/* us */
embedded_metadata_height = "1";
dmesg information is as follows:
[ 109.695763] isx031 10-001a: sensor5 set mode in 0!!!
[ 109.725683] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 115, flags: 0, err_data 262144
[ 109.736086] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 109.736088] vi5_capture_dequeue: b. embedded_buffer_size: 4096, vi_port: 0
[ 109.736090] vi5_capture_dequeue: copying the embedded data onto the frame buffer
[ 112.372070] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 112.381213] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 112.391499] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 112.391504] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 112.391513] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 112.399263] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 112.409968] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 112.417705] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 112.428537] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 112.438107] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 112.438108] vi5_capture_dequeue: b. embedded_buffer_size: 4096, vi_port: 0
[ 112.438110] vi5_capture_dequeue: copying the embedded data onto the frame buffer
[ 112.458895] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 197, flags: 0, err_data 262144
[ 112.469317] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 112.469318] vi5_capture_dequeue: b. embedded_buffer_size: 4096, vi_port: 0
[ 112.469320] vi5_capture_dequeue: copying the embedded data onto the frame buffer
[ 115.188005] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 115.197203] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 115.207228] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 115.207233] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 115.207241] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 115.214979] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 115.225650] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 115.233379] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 115.244202] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 115.253703] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 115.253705] vi5_capture_dequeue: b. embedded_buffer_size: 4096, vi_port: 0
[ 115.253706] vi5_capture_dequeue: copying the embedded data onto the frame buffer
[ 115.292304] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 282, flags: 0, err_data 262144
[ 115.302681] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 115.302682] vi5_capture_dequeue: b. embedded_buffer_size: 4096, vi_port: 0
[ 115.302684] vi5_capture_dequeue: copying the embedded data onto the frame buffer
[ 118.003981] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 118.013122] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 118.023192] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 118.023196] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 118.023203] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 118.030922] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 118.041594] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 118.049316] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 118.060118] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
[ 118.069620] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 118.069621] vi5_capture_dequeue: b. embedded_buffer_size: 4096, vi_port: 0
[ 118.069623] vi5_capture_dequeue: copying the embedded data onto the frame buffer
[ 118.092061] tegra-camrtc-capture-vi tegra-capture-vi: corr_err: discarding frame 366, flags: 0, err_data 262144
[ 118.102467] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 118.102469] vi5_capture_dequeue: b. embedded_buffer_size: 4096, vi_port: 0
[ 118.102470] vi5_capture_dequeue: copying the embedded data onto the frame buffer
[ 120.628027] tegra-camrtc-capture-vi tegra-capture-vi: uncorr_err: request timed out after 2500 ms
[ 120.637160] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: attempting to reset the capture channel
[ 120.647235] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 120.647240] vi5_capture_dequeue: a. embedded_buffer_size: 4096
[ 120.647246] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 120.654972] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_close: Error in closing stream_id=2, csi_port=2
[ 120.665649] (NULL device *): vi_capture_control_message: NULL VI channel received
[ 120.673369] t194-nvcsi 13e40000.host1x:nvcsi@15a00000: csi5_stream_open: VI channel not found for stream- 2 vc- 0
[ 120.684158] tegra-camrtc-capture-vi tegra-capture-vi: err_rec: successfully reset the capture channel
The trace log is as follows:
trace.txt (255.2 KB)
Currently isx031 only opens the top row of ebd data, and the data format is UYVY. Based on the printed information, I don’t seem to see ebd data being added to frame_buf. According to the information I provide, I hope to get some of your suggestions!
