I have a test file which just consists of #include <string_view>. This leads to the error cannot open source file "string_view". About this, the reference guide (HPC Compiler Reference Manual Version 23.3 for ARM, OpenPower, x86) states that NVC++ does not include a C++ standard library and mentions stdt::string_view explicitly among the libraries which need to be provided externally.
I’m using the HPC SDK 23.3. Within its installation directory, I found string_view include files, but providing them with -I just gives the multitude of error messages in the file in test_stringview.out (21.8 KB). There are various syntax errors which are due to unexpanded macros.
Similar things happen when I use string_view includes from GCC installations. Also, the -std=gnu++17 option does not change the result.
What is the usual way to include std::string_view and the other libraries? I guess that various other include paths need to be set.
The header file directory you’re pointing at is for the CUDA C++ STL and not intended for the host.
What you need is a GNU STL installation that supports C++ 17. Something like 9.3 or newer.
What g++ version do you have installed?
By default, nvc++ will be configured to use the default GNU STL installed on the system. You can change which version nvc++ uses via the “–gcc-toolchain=/path/to/gnu/install” flag.
Alternatively, you can update the NVHPC configuration file “localrc” via the command:
