Incompatibility of torchaudio in NGC PyTorch Container 25.12 on DGX Spark (Blackwell GB10)
I recently acquired the new NVIDIA DGX Spark (Blackwell GB10 / aarch64 architecture). I am currently using the official NVIDIA NGC container: nvcr.io/nvidia/pytorch:25.12-py3.
While the pre-installed PyTorch 2.10.0a0 works perfectly with the GB10 GPU, I found that torchaudio is missing from the container. This is a critical issue for ASR/TTS workflows.
I have attempted the following solutions without success:
  1. PIP Installation: Running pip install torchaudio fetches the +cpu version from PyPI, which uninstalls the optimized NVIDIA PyTorch build and breaks CUDA support.
  2. Source Compilation: Attempting to build torchaudio from source (main branch) against the container’s PyTorch fails due to missing or relocated headers (e.g., torch/csrc/stable/device.h and torch/headeronly/core/TensorAccessor.h). It seems the header layout in this specific 2.10.0a0 alpha build is non-standard.
  3. NVIDIA PyPI: I checked pypi.nvidia.com, but could not find a wheel for torchaudio that matches this specific PyTorch build on aarch64.
As a DGX user, I expect a validated and optimized software stack.
My Questions:
  1. Why is torchaudio not included in the PyTorch 25.12 NGC container for aarch64?
  2. Can NVIDIA provide an official .whl for torchaudio that is ABI-compatible with the pre-installed PyTorch 2.10.0a0 on Blackwell?
  3. If not, what is the validated procedure to build a GPU-accelerated torchaudio for this system?
This is blocking our production ASR deployment on this expensive hardware. Any immediate assistance or an official patch would be greatly appreciated.
Hi ,
this is a known issue in torchcodec. It seems no ARM+CUDA binaries are built for TorchCode.
A workaround is to use conda and the conda-forge channel
I haven’t really tested torchaudio, so I guess if you try it let me know, but I released some vllm + pytorch containers that include updated builds of torch, torchvision, and torchaudio.
This is where I announced the vllm images:
Forum Link: New pre-built vLLM Docker Images for NVIDIA DGX Spark
The vllm images are built on top of updated pytorch images.
You can try to use the image:
scitrera/dgx-spark-pytorch-dev:2.10.0-rc6-cu131
And see if that works for you.
