• Hardware Platform (GPU)
• DeepStream Version 6.4
• TensorRT Version 8.6.1
• NVIDIA GPU Driver Version (535)
I updated the python bindings so that I’m able to extract the reid feature vector out. Although I found one inconsistency there that is the ReID tensor is not available for every object in every frame of the source. This is the code I’m using:
l_batch_user=batch_meta.batch_user_meta_list
while l_batch_user is not None:
try:
user_meta= pyds.NvDsUserMeta.cast(l_batch_user.data)
except StopIteration:
break
if user_meta and user_meta.base_meta.meta_type == pyds.NVDS_TRACKER_BATCH_REID_META:
pReidTensor = pyds.NvDsReidTensorBatch.cast(user_meta.user_meta_data)
reidFeatures = pReidTensor.get_features()
try:
l_batch_user=l_batch_user.next
break
while l_obj:
try:
obj_meta=pyds.NvDsObjectMeta.cast(l_obj.data)
break
while l_user_meta:
try:
user_meta = pyds.NvDsUserMeta.cast(l_user_meta.data)
if user_meta and (user_meta.base_meta.meta_type == pyds.NVDS_TRACKER_OBJ_REID_META) and user_meta.user_meta_data:
reidInd_ptr = ctypes.cast(pyds.get_ptr(user_meta.user_meta_data), ctypes.POINTER(ctypes.c_int32))
reidInd = reidInd_ptr.contents.value
if reidInd >= 0 and reidInd < pReidTensor.numFilled:
feature = reidFeatures[reidInd, :]
Here, I don’t get a feature for every object. For some of the objects it is missed out. Can you spot any error here, or is the ReID model doesn’t work on every object for every frame?
Reid Config:
ReID:
reidType: 2 # The type of reid among { DUMMY=0, NvDEEPSORT=1, Reid based reassoc=2, both NvDEEPSORT and reid based reassoc=3}
outputReidTensor: 1
# [Reid Network Info]
batchSize: 100 # Batch size of reid network
workspaceSize: 1000 # Workspace size to be used by reid engine, in MB
reidFeatureSize: 256 # Size of reid feature
reidHistorySize: 100 # Max number of reid features kept for one object
inferDims: [3, 256, 128] # Reid network input dimension CHW or HWC based on inputOrder
networkMode: 1 # Reid network inference precision mode among {fp32=0, fp16=1, int8=2 }
# [Input Preprocessing]
inputOrder: 0 # Reid network input order among { NCHW=0, NHWC=1 }. Batch will be converted to the specified order before reid input.
colorFormat: 0 # Reid network input color format among {RGB=0, BGR=1 }. Batch will be converted to the specified color before reid input.
offsets: [123.6750, 116.2800, 103.5300] # Array of values to be subtracted from each input channel, with length equal to number of channels
netScaleFactor: 0.01735207 # Scaling factor for reid network input after substracting offsets
keepAspc: 1 # Whether to keep aspc ratio when resizing input objects for reid
# [Output Postprocessing]
addFeatureNormalization: 1 # If reid feature is not normalized in network, adding normalization on output so each reid feature has l2 norm equal to 1
minVisibility4GalleryUpdate: 0.6 # Add ReID embedding to the gallery only if the visibility is not lower than this
# [Paths and Names]
# onnxFile: "/home/ubuntu/landmark/falcon-zone-analytics-deepstream/onnx_models/swin_tiny_market1501_aicity156_featuredim256.onnx"
modelEngineFile: "onnx_models/resnet50_market1501_aicity156.onnx_b100_gpu0_fp16.engine"
