I have a lot of strange behaviour trying to import files into my project. Let me explain:
I have a 3D model of a file I created in Fusion 360 for a client and I’d like to texture and render in Create, it’s in USD format so normally it should be easy to work with. I have saved the project in my localhost to be sure all data goes there in the same place. I’ve also collected the data of this model in my localhost so all ok here.
What I don’t understand is that when I drag the file in my stage tab it isn’t visible in the scene, I only get some link icon but no model, but when I drag it in the layers tab then I can see it in my scene. Not sure this is ok but at least I can see my model.
But if the files aren’t on my localhost then when I drag it into the stage or layers I see an icon but not model in my scene, I’m sure I have managed it to work with other models but I really don’t get a clue on why sometimes files can be dragged in the stage or layers tab and in other cases don’t and why it works using layers and not stage when files are collected in localhost.
Now if I double click on the usd model on my desktop before collecting it, it opens by magic in a new project and it appears in both stage and layers tabs
I’d really like to start working with Create but I must admit that this all makes it very confusing for me. I’m sure I need to get used to it more, but I have to admit it’s more complex then what I used to do before in Cinema 4D, Keyshot etc.
thanks
