On a Jetson TX-1 we are seeing very inconsistent WiFi performance. To troubleshoot I ran this small script to repeatedly show signal strength for nearby AP’s:
while true; do sudo iwlist wlan0 scan | egrep 'Cell |Encryption|Quality|Last beacon|ESSID|Frequency' >> wifiscan; sleep 3; echo "-----" >> wifiscan; done
In the output below there are a few issues I am trying to understand:
Several entries have ESSID:“”. I don’t see these empty SSID’s with any of several WiFi analyzer tools running on co-located (same desk) Android, iOS and Linux machines.
The empty ESSID’s sometimes share a MAC address, or are very close to other MAC addresses (for example lines 5/6, 50/51) below.
The signal level is sometimes shown as 0dBm and Quality 70/70 (lines 10/11, 18, 50/51) for both valid and empty SSID’s. At other times a different (and likely more legitimate) signal level is shown.
This occurs on a stock TX-1 Devkit with the stock antennas and has been verified on two different TX-1’s, both with the -400 serial number suffix. Are these normal occurrences?
Cell 01 - Address: 78:24:AF:7A:F1:04 Frequency:5.2 GHz (Channel 40) Quality=58/70 Signal level=-52 dBm Encryption key:on ESSID:"ASUS_5G" Extra: Last beacon: 100ms ago
Cell 02 - Address: 08:86:3B:22:8F:4C Frequency:2.412 GHz (Channel 1) Quality=25/70 Signal level=-85 dBm Encryption key:on ESSID:"LifeIsGood" Extra: Last beacon: 100ms ago
Cell 03 - Address: 78:24:AF:7A:F1:00 Frequency:2.442 GHz (Channel 7) Quality=65/70 Signal level=-45 dBm Encryption key:on ESSID:"ASUS-24" Extra: Last beacon: 100ms ago
Cell 04 - Address: B2:CA:B5:AA:3A:00 Frequency:2.412 GHz (Channel 1) Quality=20/70 Signal level=-90 dBm Encryption key:on ESSID:"" Extra: Last beacon: 14380ms ago
Cell 05 - Address: 00:1D:D5:8B:AC:50 Frequency:2.412 GHz (Channel 1) Quality=21/70 Signal level=-89 dBm Encryption key:on ESSID:"Stefano" Extra: Last beacon: 4840ms ago
Cell 06 - Address: 02:1D:D5:8B:AC:50 Frequency:2.412 GHz (Channel 1) Quality=18/70 Signal level=-92 dBm Encryption key:on ESSID:"" Extra: Last beacon: 14380ms ago
Cell 07 - Address: DC:EF:09:3C:ED:91 Frequency:2.412 GHz (Channel 1) Quality=20/70 Signal level=-90 dBm Encryption key:on ESSID:"NETGEAR61_EXT" Extra: Last beacon: 100ms ago
Cell 01 - Address: 78:24:AF:7A:F1:04 Frequency:5.2 GHz (Channel 40) Quality=58/70 Signal level=-52 dBm Encryption key:on ESSID:"ASUS_5G" Extra: Last beacon: 90ms ago
Cell 02 - Address: 08:86:3B:22:8F:4C Frequency:2.412 GHz (Channel 1) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"LifeIsGood" Extra: Last beacon: 90ms ago
Cell 03 - Address: 78:24:AF:7A:F1:00 Frequency:2.442 GHz (Channel 7) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"ASUS-24" Extra: Last beacon: 90ms ago
Cell 04 - Address: 00:1D:D5:8B:AC:50 Frequency:2.412 GHz (Channel 1) Quality=21/70 Signal level=-89 dBm Encryption key:on ESSID:"Stefano" Extra: Last beacon: 9580ms ago
Cell 05 - Address: DC:EF:09:3C:ED:91 Frequency:2.412 GHz (Channel 1) Quality=20/70 Signal level=-90 dBm Encryption key:on ESSID:"NETGEAR61_EXT" Extra: Last beacon: 4840ms ago
Cell 06 - Address: BC:CA:B5:AA:3A:00 Frequency:2.412 GHz (Channel 1) Quality=20/70 Signal level=-90 dBm Encryption key:on ESSID:"HOME-3A02" Extra: Last beacon: 90ms ago
Cell 02 - Address: 08:86:3B:22:8F:4C Frequency:2.412 GHz (Channel 1) Quality=26/70 Signal level=-84 dBm Encryption key:on ESSID:"LifeIsGood" Extra: Last beacon: 90ms ago
Cell 04 - Address: 00:1D:D5:8B:AC:50 Frequency:2.412 GHz (Channel 1) Quality=21/70 Signal level=-89 dBm Encryption key:on ESSID:"Stefano" Extra: Last beacon: 14300ms ago
Cell 05 - Address: DC:EF:09:3C:ED:91 Frequency:2.412 GHz (Channel 1) Quality=20/70 Signal level=-90 dBm Encryption key:on ESSID:"NETGEAR61_EXT" Extra: Last beacon: 9560ms ago
Cell 06 - Address: BC:CA:B5:AA:3A:00 Frequency:2.412 GHz (Channel 1) Quality=20/70 Signal level=-90 dBm Encryption key:on ESSID:"HOME-3A02" Extra: Last beacon: 4810ms ago
Cell 07 - Address: BE:34:26:53:51:EE Frequency:2.437 GHz (Channel 6) Quality=22/70 Signal level=-88 dBm Encryption key:on ESSID:"" Extra: Last beacon: 90ms ago
Cell 01 - Address: 78:24:AF:7A:F1:04 Frequency:5.2 GHz (Channel 40) Quality=57/70 Signal level=-53 dBm Encryption key:on ESSID:"ASUS_5G" Extra: Last beacon: 90ms ago
Cell 02 - Address: 08:86:3B:22:8F:4C Frequency:2.412 GHz (Channel 1) Quality=25/70 Signal level=-85 dBm Encryption key:on ESSID:"LifeIsGood" Extra: Last beacon: 90ms ago
Cell 04 - Address: DC:EF:09:3C:ED:91 Frequency:2.412 GHz (Channel 1) Quality=18/70 Signal level=-92 dBm Encryption key:on ESSID:"NETGEAR61_EXT" Extra: Last beacon: 90ms ago
Cell 05 - Address: BC:CA:B5:AA:3A:00 Frequency:2.412 GHz (Channel 1) Quality=20/70 Signal level=-90 dBm Encryption key:on ESSID:"HOME-3A02" Extra: Last beacon: 9640ms ago
Cell 06 - Address: BE:34:26:53:51:EE Frequency:2.437 GHz (Channel 6) Quality=22/70 Signal level=-88 dBm Encryption key:on ESSID:"" Extra: Last beacon: 4920ms ago
Cell 01 - Address: 78:24:AF:7A:F1:04 Frequency:5.2 GHz (Channel 40) Quality=57/70 Signal level=-53 dBm Encryption key:on ESSID:"ASUS_5G" Extra: Last beacon: 100ms ago
Cell 02 - Address: 08:86:3B:22:8F:4C Frequency:2.412 GHz (Channel 1) Quality=22/70 Signal level=-88 dBm Encryption key:on ESSID:"LifeIsGood" Extra: Last beacon: 100ms ago
Cell 03 - Address: 78:24:AF:7A:F1:00 Frequency:2.442 GHz (Channel 7) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"ASUS-24" Extra: Last beacon: 100ms ago
Cell 04 - Address: DC:EF:09:3C:ED:91 Frequency:2.412 GHz (Channel 1) Quality=18/70 Signal level=-92 dBm Encryption key:on ESSID:"NETGEAR61_EXT" Extra: Last beacon: 4820ms ago
Cell 05 - Address: BC:CA:B5:AA:3A:00 Frequency:2.412 GHz (Channel 1) Quality=20/70 Signal level=-90 dBm Encryption key:on ESSID:"HOME-3A02" Extra: Last beacon: 14370ms ago
Cell 06 - Address: BE:34:26:53:51:EE Frequency:2.437 GHz (Channel 6) Quality=22/70 Signal level=-88 dBm Encryption key:on ESSID:"" Extra: Last beacon: 9650ms ago
Cell 02 - Address: 08:86:3B:22:8F:4C Frequency:2.412 GHz (Channel 1) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"LifeIsGood" Extra: Last beacon: 100ms ago
Cell 04 - Address: DC:EF:09:3C:ED:91 Frequency:2.412 GHz (Channel 1) Quality=18/70 Signal level=-92 dBm Encryption key:on ESSID:"NETGEAR61_EXT" Extra: Last beacon: 9550ms ago
Cell 05 - Address: BE:34:26:53:51:EE Frequency:2.437 GHz (Channel 6) Quality=22/70 Signal level=-88 dBm Encryption key:on ESSID:"" Extra: Last beacon: 14380ms ago
Cell 06 - Address: 84:00:2D:57:E2:5B Frequency:2.437 GHz (Channel 6) Quality=20/70 Signal level=-90 dBm Encryption key:off ESSID:"" Extra: Last beacon: 100ms ago
Cell 02 - Address: 08:86:3B:22:8F:4C Frequency:2.412 GHz (Channel 1) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"LifeIsGood" Extra: Last beacon: 4870ms ago
Cell 04 - Address: DC:EF:09:3C:ED:91 Frequency:2.412 GHz (Channel 1) Quality=18/70 Signal level=-92 dBm Encryption key:on ESSID:"NETGEAR61_EXT" Extra: Last beacon: 14320ms ago
Cell 05 - Address: 84:00:2D:57:E2:5B Frequency:2.437 GHz (Channel 6) Quality=20/70 Signal level=-90 dBm Encryption key:off ESSID:"" Extra: Last beacon: 4870ms ago
Cell 06 - Address: BC:CA:B5:AA:3A:00 Frequency:2.412 GHz (Channel 1) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"HOME-3A02" Extra: Last beacon: 90ms ago
Cell 07 - Address: B2:CA:B5:AA:3A:00 Frequency:2.412 GHz (Channel 1) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"" Extra: Last beacon: 90ms ago
Cell 08 - Address: 02:1D:D5:8B:AC:50 Frequency:2.412 GHz (Channel 1) Quality=21/70 Signal level=-89 dBm Encryption key:on ESSID:"" Extra: Last beacon: 90ms ago
Cell 02 - Address: 08:86:3B:22:8F:4C Frequency:2.412 GHz (Channel 1) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"LifeIsGood" Extra: Last beacon: 9680ms ago
Cell 03 - Address: 78:24:AF:7A:F1:00 Frequency:2.442 GHz (Channel 7) Quality=64/70 Signal level=-46 dBm Encryption key:on ESSID:"ASUS-24" Extra: Last beacon: 100ms ago
Cell 04 - Address: 84:00:2D:57:E2:5B Frequency:2.437 GHz (Channel 6) Quality=20/70 Signal level=-90 dBm Encryption key:off ESSID:"" Extra: Last beacon: 9680ms ago
Cell 05 - Address: BC:CA:B5:AA:3A:00 Frequency:2.412 GHz (Channel 1) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"HOME-3A02" Extra: Last beacon: 4900ms ago
Cell 06 - Address: B2:CA:B5:AA:3A:00 Frequency:2.412 GHz (Channel 1) Quality=70/70 Signal level=0 dBm Encryption key:on ESSID:"" Extra: Last beacon: 4900ms ago
Cell 07 - Address: 02:1D:D5:8B:AC:50 Frequency:2.412 GHz (Channel 1) Quality=21/70 Signal level=-89 dBm Encryption key:on ESSID:"" Extra: Last beacon: 4900ms ago
