• Hardware Platform (Jetson / GPU) both
• DeepStream Version
6.3
• TensorRT Version
Questions re: new Streammux plugin - frame-duration
property.
The Deepstream docs for new Streammux define the frame-duration
property as
Duration of input frames in milliseconds for use in NTP timestamp correction based on frame rate. If set to 0 (default), frame duration is inferred automatically from PTS values seen at RTP jitter buffer. When there is change in frame duration between the RTP jitter buffer and the nvstreammux, this property can be used to indicate the correct frame rate to the nvstreammux, for e.g. when there is an audiobuffersplit GstElement before nvstreammux in the pipeline. If set to -1, disables frame rate based NTP timestamp correction.
Signed integer, -1 to - 147483647
gst-inspect-1.0 shows
frame-duration : Duration of input frames in milliseconds for use in NTP timestamp correction based on frame rate.
If set to 0, frame duration is inferred automatically from PTS values.
If set to -1, disables frame rate based NTP timestamp correction (default).
flags: readable, writable
Unsigned Integer64. Range: 0 - 18446744073709551615 Default: 18446744073709
I’m assuming both are wrong and that it should be a Signed Integer64
And when I read the default plugin value I definitely get 18446744073709 not 0
