I have some code which when compiled with options -C -Mchkptr returns the diagnostic abort
0: Null pointer for x%p (pgi_check.f90: 21)
I see no indication in Metcalfe, Reid and Cohen’s book that it is an error to call “associated” with a null pointer. Surely it ought simply to return .FALSE.
The diagnostic abort only occurs for the two-argument form of the “associated”
intrinsic. IIt alsogoes away if the pointeris not a member of a derived type.
I think this is a bug and the diagnostic is incorrect - but am willing to be corrected.
module m
integer,save,pointer :: x,y
contains
subroutine init(x,y)
integer,pointer, intent(inout) :: x,y
nullify(x)
nullify(y)
end subroutine init
subroutine check_assoc
if( associated(x,y) ) then
write(*,*) "Yes"
else
write(*,*) "No"
end if
end subroutine check_assoc
end module m
program assoc_test
use m
nullify(x)
nullify(y)
call init(x,y)
call check_assoc
end program assoc_test
Hi Keith,
I’m not able to recreate this one. What compiler version and OS are you using? Are you running 32 or 64-bits? Are there any other compile options?
Thanks,
Mat
% cat chkptr.f90
module m
contains
nullify(x)
nullify(y)
end subroutine init
write(*,*) "Yes"
else
write(*,*) "No"
end if
end module m
program assoc_test
use m
nullify(x)
nullify(y)
call init(x,y)
call check_assoc
% pgf90 -C -Mchkptr chkptr.f90 -V12.9
% a.out
No
Oops - I included the wrong code. This is the one which fails (with 12.9)
module m
type t
complex, pointer, dimension(:) :: p => null()
complex, allocatable, dimension(:) :: q
end type t
contains
subroutine init(x)
type(t), intent(inout) :: x
nullify(x%p)
end subroutine init
subroutine check_assoc(x)
type(t), intent(inout), target :: x
if( associated(x%p,x%q) ) then
write(*,*) "Yes"
else
write(*,*) "No"
end if
end module m
program assoc_test
use m
type(t) :: x
call init(x)
call check_assoc(x)
Thanks Keith. I sent this off to engineering and they agree that it’s a compiler error. They will have a fix in place in as of the the 13.0 compilers.
