pgf95 compiles the following code:
program test
character(8) :: foo = 'foo', bar = 'bar'
print *, '"'//trimconcat(foo,bar)//'"'
contains
function trimconcat(a, b)
character(*), intent(in) :: a, b
character(len_trim(trim(a)//b)) :: trimconcat
trimconcat = trim(trim(a)//b)
end function trimconcat
end program test
However, the following output is produced during execution:
0: ALLOCATE: 18446744072635804528 bytes requested; not enough memory
I expected “foobar” to be printed. Does this work in the most recent pgf95?
I am using pgf95 6.2-3 64-bit target on x86-64 Linux.
Hi rusteve,
Thank you for the report and example code. I have filed a technical problem report (TPR#4254) and have sent the issue to our compiler team for further review. The problem is caused by a compiler generated temporary variable to hold the result of “trim(a)” within “len_trim(trim(a)//b)”. Unfortunately, the only work around I see is to move the trim intrinsic from “trimconcat” to the caller.
For example:
% cat trim2.f90
program test
print *, '"'//trimconcat(trim(foo),bar)//'"'
contains
character(len_trim(a//b)) :: trimconcat
trimconcat = a//b
end program test
% pgf90 trim2.f90
% a.out
"foobar"
Best Regards,
Mat
Hi rusteve,
We found a better work around:
% cat trim3.f90
program test
contains
character(len_trim(a)+len_trim(b)) :: trimconcat
end program test
% a.out
"foobar"
I can confirm that this works. Thanks!
