GPU
• DeepStream Version
5.0.1
• TensorRT Version
I made a small change to gst-dsexample plugin.
I added a background-substraction function using opencv, but results were not as expected.
for debugging purposes, I decided to save the input image prior to any other custom change, using
cv::imwrite(filename,in_mat); (and then I commented everything else)
the surprise was to find that the saved image didn’t had the correct colors.
this is the image I got:
and this is the image I expected (the same I can see on the rttsp sink)
the app I ran is deepstream-opencv-example. On the app I only changed the sink to rtsp
what could be causing this issue?
