% cat bad.f90
program bad
implicit none
integer, parameter :: N = huge(N), M = 10
integer :: i, j
outer: do i = M, N
do j = 1, M
if (mod(i,j) /= 0) cycle outer
end do
exit outer
end do outer
print *, i
end program bad
% pgf90 -O1 -o bad bad.f90
% ./bad
2520
% pgf90 -O2 -o bad bad.f90
% ./bad
11
% pgf90 -V
pgf90 8.0-5 64-bit target on x86-64 Linux -tp core2-64
Copyright 1989-2000, The Portland Group, Inc. All Rights Reserved.
Copyright 2000-2009, STMicroelectronics, Inc. All Rights Reserved.
I suppose my value of N is somewhat sketchy to use as the upper bound of the do-loop, so this may not really be a bug, although it is a bit of a surprise. In fact, changing the value of N to huge(N) - 1 does fix the problem. Oddly enough, using modulo instead of mod also fixes the problem.
