Thanks for the response as always. I do not mean to “ignore” your suggestion to check the depthwise-conv layer however I do not believe this is the root of the problem. I have another network i.e. vgg_16 that I converted to the .uff format and it is experiencing the same issues as mobilenet. The vgg_16 network does not have a depthwise-conv layer. I will share its python source to show this.
Also it seems that the output from conv layers in all networks I have checked are not the same between Tensorflow and TensorRT. Even the lenet network that works properly on TensorRT, whenever I compare its convolutional layers between tensorflow and tensorrt, the results are different. Even though it works properly, shouldn’t all layers be the same? My comparison method is the same as the one in the code I pasted below.
I wrote a code similar to what you asked me to do for depthwise-conv but instead I did it for a normal convolution layer. In particular slim.conv2d and even tf.nn.conv2d and in both cases the output was different between Tensorflow and TensorRT. My code for this is below:
#Implement simple 1-layer network tensorflow
#Will check slim.conv2d
import tensorrt as trt
import pycuda.driver as cuda
import tensorflow as tf
import numpy as np
from tensorflow.python.framework import graph_util
import uff
from tensorrt.parsers import uffparser
slim = tf.contrib.slim
RANDOM_SEED = 42
tf.set_random_seed(RANDOM_SEED)
def sumArray(array):
holder=0
for i in range(len(array)):
holder=holder+array[i]
return holder
def isclose(a, b, rel_tol=1e-05, abs_tol=0.00003):
return abs(a-b) <= max(rel_tol * max(abs(a), abs(b)), abs_tol)
def compare_arrays(array1,array2):
if(len(array1)!=len(array2)):
return False
for i in range(len(array1)):
status=isclose(array1[i],array2[i])
if(status==False):
return False
return True
def init_weights(shape):
""" Weight initialization """
weights = np.ones(shape)
#native
#weights=tf.ones(shape)
return weights
def get_data():
inputs=np.random.rand(1,28,28,3)
return inputs
def forward_prop(inputs):
#native
ones=init_weights([3,3,3,32])
net=tf.nn.conv2d(inputs,ones,strides=[1,2,2,1],padding='SAME')
return net
#tf-slim
# ones=init_weights([3,3,32])
# weights_init=tf.constant_initializer(ones)
# with slim.arg_scope([slim.conv2d], padding='VALID',weights_initializer=weights_init):
# net=slim.conv2d(inputs, 32,[3, 3],stride=2)
# return net
def main():
train_X=get_data()
tensorrt_input=train_X.reshape(3,28,28)
tensorrt_input=tensorrt_input.astype(np.float32)
X = tf.placeholder("float", shape=[1, 28, 28, 3])
h_conv1=forward_prop(X)
# saver = tf.train.Saver()
init = tf.global_variables_initializer()
sess = tf.Session()
sess.run(init)
tf.train.write_graph(sess.graph_def, '.', 'hellotensor.pbtxt')
final_result=sess.run(h_conv1,feed_dict={X:train_X})
# print(final_result)
#saver.save(sess, './hellotensor.ckpt')
output_graph_name='./hellotensor.pb'
output_node_names='Conv2D'
output_graph_def = graph_util.convert_variables_to_constants(sess,sess.graph_def,output_node_names.split(","))
output_graph_def = tf.graph_util.remove_training_nodes(output_graph_def)
uff_model = uff.from_tensorflow(output_graph_def, output_nodes=['Conv2D'])
dump = open('slimConv.uff', 'wb')
dump.write(uff_model)
dump.close()
# with tf.gfile.GFile(output_graph_name, "wb") as f:
# f.write(output_graph_def.SerializeToString())
uff_model = open("/home/dami/TensorRt_test/slimConv.uff", 'rb').read()
G_LOGGER = trt.infer.ConsoleLogger(trt.infer.LogSeverity.ERROR)
parser = uffparser.create_uff_parser()
parser.register_input("Placeholder", (3, 28, 28), 0)
parser.register_output("Conv2D")
engine = trt.utils.uff_to_trt_engine(G_LOGGER, uff_model, parser, 1, 1 << 20)
parser.destroy()
runtime = trt.infer.create_infer_runtime(G_LOGGER)
context = engine.create_execution_context()
dims_data = engine.get_binding_dimensions(0).to_DimsCHW()
dims_out1 = engine.get_binding_dimensions(1).to_DimsCHW()
_out0 = np.empty(dims_data.C() * dims_data.H() * dims_data.W(), dtype=np.float32)
_out1 = np.empty(dims_out1.C() * dims_out1.H() * dims_out1.W(), dtype=np.float32)
d_out0 = cuda.mem_alloc(1 * dims_data.C() * dims_data.H() * dims_data.W() * _out0.dtype.itemsize)
d_out1 = cuda.mem_alloc(1 * dims_out1.C() * dims_out1.H() * dims_out1.W() * _out1.dtype.itemsize)
bindings = [int(d_out0), int(d_out1)]
stream = cuda.Stream()
# transfer input data to device
cuda.memcpy_htod_async(d_out0, tensorrt_input, stream)
# execute model
context.enqueue(1, bindings, stream.handle, None)
# transfer predictions back
cuda.memcpy_dtoh_async(_out1, d_out1, stream)
# synchronize threads
stream.synchronize()
# re_array=_out1.reshape((13, 13, 32))
if (_out1.shape != final_result.shape):
results = final_result.reshape(_out1.shape)
print(str(compare_arrays(results, _out1)))
print(sumArray(_out1))
print(sumArray(results))
context.destroy()
engine.destroy()
runtime.destroy()
if __name__ == '__main__':
main()
Is it possible there is some issue with the conv layers? The output from this code is:
Converted 0 variables to const ops.
Using output node Conv2D
Converting to UFF graph
No. nodes: 4
False
80897.3109283
81799.3861542
As you can see the output is different and the sum of the outputs are different as well. Am I doing something wrong? Is there a certain amount of tolerance, I need to allow? I am also very confused on how the conv layers of the Lenet network give different outputs but the final results are correct. Sorry again for the long questions. I really appreciate all the help.Thanks!!
vgg.zip (2.27 KB)
