I have 3 Xaviers and have successfully flashed the first two via Manual Setup. The third has a previously installed OS on it and I would like to update it.
I am using the SDK Manager to flash it, have connected the included USB-c cable from the Xavier to my host machine, and (after running ifconfig enp0s20f0u2 192.168.55.100
on the host) am able to ping/SSH in to the Xavier from the host machine (ssh nvidia@192.168.55.1
However, when running SDK Manager and going through the flash step with “Automatic Setup”, after entering either the default (nvidia/nvidia) credentials, or ones for a user I have created on the system, it hangs for a minute and then shows “Incorrect username or password.” I again have confirmed that from a terminal on the host machine, I can SSH to the machine with the same IP adress and credentials entered into the SDK Manager flash setup screen.
Snippet from the logs:
11:17:59 DEBUG : running command < [ `lsusb | grep -c "0955:"` -ne 1 ] >
11:17:59 ERROR : command terminated with error
11:17:59 INFO : Only one nvidia device detected, as expected.
11:17:59 DEBUG : running command < ip addr | grep 192.168.55.1 >
11:17:59 INFO : inet 192.168.55.100/24 brd 192.168.55.255 scope global enp0s20f0u2
11:17:59 INFO : command finished successfully
11:17:59 DEBUG : running command < nc -z -vv -w 5 192.168.55.1 22 >
11:17:59 INFO : Connection to 192.168.55.1 22 port [tcp/ssh] succeeded!
11:17:59 INFO : Connection to the device via SSH is avaliable.
11:17:59 DEBUG : running command < ssh -F /dev/null -o PubkeyAuthentication=no -o UserKnownHostsFile=/dev/null -o StrictHostKeyChecking=no -o ConnectTimeout=5 nvidia@192.168.55.1 echo hello >
11:18:00 INFO : Warning: Permanently added '192.168.55.1' (ECDSA) to the list of known hosts.
11:20:00 INFO : Password:
11:20:00 INFO :
11:20:00 INFO : Connection closed by 192.168.55.1 port 22
11:20:00 ERROR : command terminated with error
11:20:00 ERROR : Incorrect username or password.
