Incorret frame_meta size
• Hardware Platform Jetson
• DeepStream Version 6.3
• JetPack Version 5.1.2
• TensorRT Version
I have 2 video streams, when I run with below command
deepstream-test3-app file:////opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4 file:////opt/nvidia/deepstream/deepstream/samples/streams/sample_720p.mp4
During tiler_src_pad_buffer_probe, I can see there are 2 frame_meta for each stream.
But when I try to debug into msgconv,
in the deepstream-6.3\sources\gst-plugins\gst-nvmsgconv\gstnvmsgconv.c
in the method gst_nvmsgconv_transform_ip, I can see there is only 1 frame_meta. And all of NvDsEventMsgMeta are binding with this frame_meta.
This cause a problem for my side. It means I can’t split NvDsEventMsgMeta for different stream.
Is there a way don’t merge frame_meta into 1? And I want to understand why do you merge into 1 frame_meta?
1.nvmultistreamtiler will merge multiple frames in the batch into one, and the frame meta will also be merged.
2.The function tiler_src_pad_buffer_probe in test3 is added to pgie’s src pad, so the frames have not yet been merged.
3.Remove the tiler, add nvstreamdemux and add nvmsgconv and nvmsgbroker after the src pad of each nvstreamdemux
              |-------------- nvmsgconv  -- nvmsgbroker
nvstreamdemux |
@junshengy Thanks for your explanation.
