I have a high bit rate stream being received through I2S and get the occasional overrun so I would like to increase the buffer size.
L4T docs say to edit the tegra_alt_pcm_hardware
struct in
kernel/nvidia/sound/soc/tegra-alt/utils/tegra_pcm_alt.c
static const struct snd_pcm_hardware tegra_alt_pcm_hardware = {
.info = SNDRV_PCM_INFO_MMAP |
SNDRV_PCM_INFO_MMAP_VALID |
SNDRV_PCM_INFO_PAUSE |
SNDRV_PCM_INFO_RESUME |
SNDRV_PCM_INFO_INTERLEAVED,
.formats = SNDRV_PCM_FMTBIT_S8 |
SNDRV_PCM_FMTBIT_S16_LE |
SNDRV_PCM_FMTBIT_S24_LE |
SNDRV_PCM_FMTBIT_S20_3LE |
SNDRV_PCM_FMTBIT_S32_LE,
.period_bytes_min = 128,
.period_bytes_max = PAGE_SIZE * 4,
.periods_min = 1,
.periods_max = 8,
.buffer_bytes_max = PAGE_SIZE * 8,
.fifo_size = 4,
to just increase the value of buffer_bytes_max
should I also proportionally increase period_bytes_max
or any other values such as in this post?
Also is there a limit to what the buffer size can be?
