hi everyone,
i’ve been trying to increase the quality of my h.264 to h.265 gstreamer transcoding on the jetson nano. obviously the bitrate has a great effect, but are there any other ways to tweak the outcome? encoding performance is not an issue (i don’t care how long it takes). so far i have come up with this:
/usr/bin/gst-launch-1.0 filesrc location="$1" ! \
matroskademux name=demux ! queue ! \
h264parse ! \
omxh264dec ! progressreport update-freq=1 ! \
videorate ! video/x-raw,framerate=23/1 ! \
omxh265enc bitrate=1300000 preset-level=3 EnableTwopassCBR=1 control-rate=2 iframeinterval=50 ! \
matroskamux name=mux ! \
filesink location="$2"
i have also tried to use 10-bit encoding by supplying the “I420_10LE” format string, but that doesn’t work. however, using “I420” instead does work. so, does anyone know how to use the 10-bit colourspace when transcoding from h.264?
the following example fails with a coredump:
h264parse ! \
nvvidconv ! 'video/x-raw(memory:NVMM), format=(string)<b>I420_10LE</b>' ! \
