Increasing number of fraction digits in reported metrics
Hi
Is there any way to increase the number of digits for fractions in the reported metric? For example, a reported IPC is 0.01 while the actual number is 0.0143. For large numbers, that may not cause a problems, but for low numbers it has some accuracy effects in my calculations.
There currently is no setting in the CLI or UI to change the precision of how these values are reported. We’ll consider changing this in a future release.
In the meantime, you can use the python report interface to access the underlying report file using python directly. This allows you to print values in your desired precision.
As a further note, you can see a higher-precision value in the UI’s tooltips, when hovering over the respective entry in the section tables.
