Hello. I got the ** list index out of range** error when I do inference for DashCamnet. What’s the reason for making this error ?
The model is resnet18_dashcamnet.tlt
Tao Toolkit version is 4.0.1
Thank you for your help in advance.
Here is my command
sudo docker run -it --rm -v /home/ubuntu/tao_test_2023/:/workspace/tao-experiments
nvcr.io/nvidia/tao/tao-toolkit:4.0.0-tf1.15.5
detectnet_v2 inference
-e /workspace/tao-experiments/specs_edit.txt
-o /workspace/tao-experiments
-i /workspace/tao-experiments/data
-k tlt_encode
Here is my inference spec file
inferencer_config{ # defining target class names for the experiment.
# Note: This must be mentioned in order of the networks classes.
target_classes: "car"
#target_classes: "cyclist"
#target_classes: "pedestrian"
# Inference dimensions.
image_width: 1248
image_height: 384
# Must match what the model was trained for.
image_channels: 3
batch_size: 16
gpu_index: 0
# model handler config
tlt_config{
# model: "/workspace/tao-experiments/detectnet_v2/experiment_dir_retrain/weights/resnet18_detector_pruned.tlt"
model: "/workspace/tao-experiments/resnet18_dashcamnet.tlt"
bbox_handler_config{
kitti_dump: true
disable_overlay: false
overlay_linewidth: 2
classwise_bbox_handler_config{
key:"car"
value: {
confidence_model: "aggregate_cov"
output_map: "car"
bbox_color{
R: 0
G: 255
B: 0
clustering_config{
clustering_algorithm: DBSCAN
coverage_threshold: 0.005
dbscan_eps: 0.3
dbscan_min_samples: 0.05
dbscan_confidence_threshold: 0.9
minimum_bounding_box_height: 4
According to DashCamNet | NVIDIA NGC , please change to 960 x 544
Could you please add more classes? From the ngc link, this model trained for car, persons, road signs and bicycles. So you can add more classwise_bbox_handler_config
I’ve changed the image_width and image_height to 960 and 544, and added two classes named cyclist and pedestrian .
However. I got the new error message: TypeError: unhashable type: ‘slice’
How should I do to solve this problem ?
Here is my edited inference spec file
inferencer_config{
image_width: 960
image_height: 544
image_channels: 3
batch_size: 16
gpu_index: 0
tlt_config{
#model: "/workspace/tao-experiments/detectnet_v2/experiment_dir_retrain/weights/resnet18_detector_pruned.tlt"
kitti_dump: true
key:"car"
value: {
output_map: "car"
bbox_color{
R: 0
G: 255
B: 0
clustering_config{
dbscan_eps: 0.3
key:"cyclist"
value: {
output_map: "cyclist"
bbox_color{
R: 0
G: 255
B: 255
clustering_config{
dbscan_eps: 0.3
key:"pedestrian"
value: {
output_map: "pedestrian"
bbox_color{
R: 255
G: 0
B: 0
clustering_config{
dbscan_eps: 0.3
From the ngc link, this model trained for car, persons, road signs and bicycles. Please change.
It works after I changed the targets according to your suggestions.
Thank you very much !
system
Closed
April 14, 2023, 6:05am
8
