IndexError when running inference trafficcamnet in docker
• Hardware: GeForce RTX 3050
• Network Type: Detectnet_v2
• TLT Version (Please run “tlt info --verbose” and share “docker_tag” here)
• Training spec file:
inferencer_config{
  # defining target class names for the experiment.
  # Note: This must be mentioned in order of the networks classes.
  target_classes: "car"
  # Inference dimensions.
  image_width: 960
  image_height: 544
  # Must match what the model was trained for.
  image_channels: 3
  batch_size: 1
  gpu_index: 0
  #model handler config
  tlt_config{
    model: "/home/tao/resnet18_trafficcamnet.tlt"
bbox_handler_config{
  kitti_dump: true
  disable_overlay: true
  overlay_linewidth: 4
  classwise_bbox_handler_config{
    key:"car"
    value: {
      confidence_model: "aggregate_cov"
      output_map: "car"
      bbox_color{
        R: 0
        G: 255
        B: 0
      clustering_config{
        coverage_threshold: 0.00
        dbscan_eps: 0.3
        dbscan_min_samples: 1
        minimum_bounding_box_height: 4
    key:"default"
    value: {
      bbox_color{
        R: 255
        G: 255
        B: 255
      clustering_config{
        dbscan_eps: 0.3
• How to reproduce the issue ? (This is for errors. Please share the command line and the detailed log here.)
I’m trying to run inference on trafficcamnet
in a docker container using the following command
docker run --rm --gpus all -v ./:/home/tao/ nvcr.io/nvidia/tao/tao-toolkit:5.0.0-tf1.15.5 \
detectnet_v2 inference -e /home/tao/resnet18_trafficcamnet_infer_spec.txt \
-i /home/tao/input_images/ -r /home/tao/input_images/ -k tlt_encode
and i’m getting the following error
INFO: Initialized model
INFO: Commencing inference
_________________________________________________________________
Layer (type)                 Output Shape              Param #
input_1 (InputLayer)         (None, 3, 544, 960)       0
model_1 (Model)              [(None, 4, 34, 60), (None 11558548
Total params: 11,558,548
Trainable params: 11,546,900
Non-trainable params: 11,648
  0%|          | 0/7 [00:03<?, ?it/s]
INFO: list index out of range
multiprocessing.pool.RemoteTraceback:
  File "/usr/lib/python3.8/multiprocessing/pool.py", line 125, in worker
    result = (True, func(*args, **kwds))
  File "/usr/lib/python3.8/multiprocessing/pool.py", line 48, in mapstar
    return list(map(*args))
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/postprocessor/bbox_handler.py", line 93, in render_single_image_output
    bbox_list, confidence_list = _get_bbox_and_confs(class_wise_detections[key][idx],
IndexError: list index out of range
The above exception was the direct cause of the following exception:
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/inference.py", line 294, in <module>
    raise e
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/inference.py", line 278, in <module>
    main()
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/inference.py", line 267, in main
    inference_wrapper_batch(inferencer_config, bbox_handler_config,
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/scripts/inference.py", line 190, in inference_wrapper_batch
    bboxer.render_outputs(classwise_detections,
  File "/usr/local/lib/python3.8/dist-packages/nvidia_tao_tf1/cv/detectnet_v2/postprocessor/bbox_handler.py", line 434, in render_outputs
    pool.map(partial(render_single_image_output,
  File "/usr/lib/python3.8/multiprocessing/pool.py", line 364, in map
    return self._map_async(func, iterable, mapstar, chunksize).get()
  File "/usr/lib/python3.8/multiprocessing/pool.py", line 771, in get
    raise self._value
Execution status: FAIL
the inference spec file is listed below.
The model was downloaded from TrafficCamNet | NVIDIA NGC
The error comes from https://github.com/NVIDIA/tao_tensorflow1_backend/blob/main/nvidia_tao_tf1/cv/detectnet_v2/postprocessor/bbox_handler.py#L93.
Does your model train for only one class - car?
@Morganh thanks for the quick reply. No, the model was trained on 4 classes. It wasn’t clear to me that all classes are required.
Once I’ve added the 4 classes it doesn’t error anymore. However, it doesn’t produce any output images with rendered bounding boxes even though disable_overlay: true. When kitti_dump is set to true it produces some text files.
Is there an issue with disable_overlay is there some additional configuration that is required?
That is expected. If set disable_overlay: true, then according to https://github.com/NVIDIA/tao_tensorflow1_backend/blob/c7a3926ddddf3911842e057620bceb45bb5303cc/nvidia_tao_tf1/cv/detectnet_v2/scripts/inference.py#L110 and https://github.com/NVIDIA/tao_tensorflow1_backend/blob/main/nvidia_tao_tf1/cv/detectnet_v2/postprocessor/bbox_handler.py#L128, the images will not be saved.
OK, thanks. That works. However, that’s very misleading
