Individual GPU core loads
Hi
We would like to access the individual loads of each GPU core in a C++ program
we already have a way to access the individual load of each CPU and the total load of all GPU’s. but would like something more in depth on GPU usage
how do we check the load of individual cores?
thanks
etay markman
Do you want to separate the resources for different tasks?
Currently, we only provide overall GPU core usage with tegrastats.
$ sudo tegrastats
Thanks for answering
Yes, we want to separate the resources for different tasks so we can maximize the use of available hardware,
hence why we want to be able to monitor our usage of the resources
sincerely
Etay Markman
Hi, do you have anything that can help up separate the GPU resources?
We don’t have a profiler to monitor specific GPU cores.
The simplest way to share the GPU resources from tasks is to use different streams so they can run in parallel.
Does this meet your requirements?
“We don’t have a profiler to monitor specific GPU cores.”
wow, not even simply monitor which ones are active?
“The simplest way to share the GPU resources from tasks is to use different streams so they can run in parallel.”
do you guys have a good example code for that?
“Does this meet your requirements?”
once you give an example we will look at it and tell you
GPU is different from the CPU.
For Orin, it has 2048 GPU cores so usually we check the overall utilization.
This info can simply be found from tegrastats.
Multiple streams are common to run concurrent tasks on GPU.
You can find a basic sample below:
