I’m pretty new to using the PGI accelerator compiler but have found a slight issue with the following (simplified)code:
ALLOCATE(some_arrays, Stat=jn)
IF(jn /= 0)THEN
WRITE (*,*) 'Alloc failed in simple_kernel - returning'
RETURN
END IF
!$ACC REGION copy(pta) copyin(ptb,umask,vmask) local(zgb,zga)
DO jn = 1, kjpt
DO jk=1, jpkm1, 1
DO jj=1, jpjm1, 1
Set some array values here...
END DO
END DO
END DO
!$ACC END REGION
If I compile the code as shown I get:
Accelerator restriction: induction variable live-out from loop: jn
for each line inside my nested loop (of form blah(1,jj,jk,jn) = 1.0).
However, if I change the ALLOCATE statement to use ierr, say, instead of jn to check the status then these messages go away which is what I’d expect as the value of jn isn’t used after the accelerated region.
I’m using version 11.0 of pgf90 with cuda 3.1 on a 64-bit linux box.
Cheers,
Andy.[/code]
