I want to run the network many times but each time to indicate a different layer as the output, such that if I have 100 layers, I want to run it 100 times and each time a different layer is marked as the output.
As far as I saw this can ONLY be done on the INetworkDefinition object, however if I deserialize the full network (the full 100 layers) I don’t have the INetworkDefinition object to do so… and therefore I need to build the network 100 times? which takes huge amounts of time…
Is there any easier way to do this?
thanks
Eyal
