Description
After changing my network from static to dynamic, the program crash at inferDeleter when destroying the objects. I got the following assertion
[04/28/2021-10:27:22] [F] [TRT] Assertion failed: !mProfiles.empty() || mIsAllDimensionsStatic
C:\source\rtExt\engine.cpp:1885
What do I need to do before destroying the objects?
Environment
TensorRT Version: TensorRT-7.2.3.4
GPU Type: NVIDIA GeForce GTX 1660 Ti with Max-Q Design
Nvidia Driver Version: 27.21.14.6079
CUDA Version: 11
CUDNN Version: 8.2
Operating System + Version: Windows 10
Python Version (if applicable):
TensorFlow Version (if applicable):
PyTorch Version (if applicable):
Baremetal or Container (if container which image + tag):
Relevant Files
Please attach or include links to any models, data, files, or scripts necessary to reproduce your issue. (Github repo, Google Drive, Dropbox, etc.)
Steps To Reproduce
Please include:
- Exact steps/commands to build your repro
- Exact steps/commands to run your repro
- Full traceback of errors encountered
Hi @oelgendy1,
Could you please share the script, model and log files so we can help better?
This is the onnx model
UNetModel.onnx (1.8 MB)
And this is the script for building the network:
context = SampleUniquePtr<nvinfer1::IExecutionContext>(mEngine->createExecutionContext());
auto builder = makeUnique(nvinfer1::createInferBuilder(sample::gLogger.getTRTLogger()));
if (!builder) return false;
const auto explicitBatch = 1U << static_cast<uint32_t>(NetworkDefinitionCreationFlag::kEXPLICIT_BATCH);
auto network = makeUnique(builder->createNetworkV2(explicitBatch));
if (!network) return false;
auto config = makeUnique(builder->createBuilderConfig());
if (!config) return false;
auto parser = makeUnique(nvonnxparser::createParser(*network, sample::gLogger.getTRTLogger()));
if (!parser) return false;
parsed = parser->parseFromFile("UNetModel.onnx", static_cast<int>(static_cast<int>(gLogger.getReportableSeverity())));
if(!parsed) return false;
builder->setMaxBatchSize(1);
config->setMaxWorkspaceSize(1_GiB);
config->setFlag(BuilderFlag::kFP16);
auto profile = builder->createOptimizationProfile();
const auto inputName = network->getInput(0)->getName();
profile->setDimensions(inputName, OptProfileSelector::kMIN, Dims4{ 1, 1, 2048, 1280 });
profile->setDimensions(inputName, OptProfileSelector::kOPT, Dims4{ 1, 1, 2080, 2080 });
profile->setDimensions(inputName, OptProfileSelector::kMAX, Dims4{ 1, 1, 2080, 2304 });
config->addOptimizationProfile(profile);
mEngine = makeUnique(builder->buildEngineWithConfig(*network, *config));
if (!mEngine) return false;
And this is the inference script
context->setBindingDimensions(0, Dims4{ 1, 1, height, width });
if (!context->allInputDimensionsSpecified()) return false;
buf[0] = (float_t*)halide_cuda_get_device_ptr(NULL, inputBuffer);
buf[1] = (float_t*)halide_cuda_get_device_ptr(NULL, outputBuffer);
if (!context->executeV2(buf)) return false;
Network is built successfully, Inference is done successfully. The crash happens at destroying the objects.
I fixed this error by destroying the context first using
context->destroy();
However, the program still crashes:
Exception thrown at 0x0000000000000000 in application.exe: 0xC0000005: Access violation executing location 0x0000000000000000.
Is it because the GPU memory is not explicitly handled by TensorRT?
My program is multi-threaded, but all neural network operations are done in single thread
Thanks for your reply @SunilJB . Yes, all variables are declared and used in a single thread. Other threads are totally independent.
Hi @oelgendy1,
We request you to please share full code. Piece of which you have shared doesn’t have much information.
Thank you.
