Hi @AastaLL
I rechecked and confirmed CAMERA_INDEX = 0, checked device is /dev/video0, rebuilt and ran again. Still same problem “Failed to query video capabilities: Inappropriate ioctl for device”.
I have pasted the whole session below
This is on jetson nano
ls /dev/v*
/dev/vcs /dev/vcs2 /dev/vcs4 /dev/vcs6 /dev/vcsa1 /dev/vcsa3 /dev/vcsa5 /dev/vhci
/dev/vcs1 /dev/vcs3 /dev/vcs5 /dev/vcsa /dev/vcsa2 /dev/vcsa4 /dev/vcsa6 /dev/video0
/dev/v4l:
by-id by-path
/dev/vfio:
vfio
grep CAMERA_INDEX *
main.cpp:static uint32_t CAMERA_INDEX = 0;
main.cpp: if (CAMERA_INDEX >= cameraDevices.size())
main.cpp: PRODUCER_PRINT(“CAMERA_INDEX out of range. Fall back to 0\n”);
main.cpp: CAMERA_INDEX = 0;
main.cpp: iCameraProvider->createCaptureSession(cameraDevices[CAMERA_INDEX]));
main.cpp: CAMERA_INDEX = atoi(optarg);
v4l2-ctl -l
brightness 0x00980900 (int) : min=0 max=255 step=1 default=128 value=128
contrast 0x00980901 (int) : min=0 max=255 step=1 default=32 value=32
saturation 0x00980902 (int) : min=0 max=255 step=1 default=32 value=32
white_balance_temperature_auto 0x0098090c (bool) : default=1 value=1
gain 0x00980913 (int) : min=0 max=255 step=1 default=64 value=64
power_line_frequency 0x00980918 (menu) : min=0 max=3 default=2 value=2
white_balance_temperature 0x0098091a (int) : min=2800 max=6500 step=1 default=5500 value=5500 flags=inactive
sharpness 0x0098091b (int) : min=0 max=255 step=1 default=22 value=22
backlight_compensation 0x0098091c (int) : min=0 max=1 step=1 default=1 value=1
exposure_auto 0x009a0901 (menu) : min=0 max=3 default=3 value=3
exposure_absolute 0x009a0902 (int) : min=3 max=2047 step=1 default=166 value=166 flags=inactive
exposure_auto_priority 0x009a0903 (bool) : default=0 value=1
pan_absolute 0x009a0908 (int) : min=-36000 max=36000 step=3600 default=0 value=0
tilt_absolute 0x009a0909 (int) : min=-36000 max=36000 step=3600 default=0 value=0
focus_absolute 0x009a090a (int) : min=0 max=255 step=5 default=60 value=60 flags=inactive
focus_auto 0x009a090c (bool) : default=1 value=1
zoom_absolute 0x009a090d (int) : min=1 max=5 step=1 default=1 value=1
make
Compiling: main.cpp
make[1]: Entering directory ‘/home/arun/work/tegra_multimedia_api/samples/common/classes’
Compiling: NvElementProfiler.cpp
Compiling: NvElement.cpp
Compiling: NvApplicationProfiler.cpp
Compiling: NvVideoDecoder.cpp
Compiling: NvJpegEncoder.cpp
Compiling: NvVideoConverter.cpp
Compiling: NvDrmRenderer.cpp
Compiling: NvLogging.cpp
Compiling: NvEglRenderer.cpp
Compiling: NvUtils.cpp
Compiling: NvBuffer.cpp
Compiling: NvJpegDecoder.cpp
Compiling: NvVideoEncoder.cpp
Compiling: NvV4l2ElementPlane.cpp
Compiling: NvV4l2Element.cpp
make[1]: Leaving directory ‘/home/arun/work/tegra_multimedia_api/samples/common/classes’
Compiling: /home/arun/work/tegra_multimedia_api/argus/samples/utils/Thread.cpp
Compiling: /home/arun/work/tegra_multimedia_api/argus/samples/utils/NativeBuffer.cpp
Compiling: /home/arun/work/tegra_multimedia_api/argus/samples/utils/nvmmapi/NvNativeBuffer.cpp
Linking: camera_recording
./camera_recording
Set governor to performance before enabling profiler
PRODUCER: Creating output stream
PRODUCER: Launching consumer thread
Opening in BLOCKING MODE
NvMMLiteOpen : Block : BlockType = 4
===== NVMEDIA: NVENC =====
NvMMLiteBlockCreate : Block : BlockType = 4
875967048
842091865
create video encoder return true
H264: Profile = 100, Level = 50
PRODUCER: Starting repeat capture requests.
