Is it possible to perform model inference for object detection using only the cpu as a device?
Hi @forflafor, if you are using a framework like PyTorch or TensorFlow, then you can choose to not have it use GPU acceleration and only run on CPU. However TensorRT only supports GPU (and DLA on Xavier).
