Hi DaneLLL,
Thank you for helping!
What would you advise to use for inference with multi camera?
I have experience with C++ but I’m confused which approach to use.
Any advice will be appreciated.
source1_csi_dec_infer_resnet_int8.txt is for single camera source. You may try it first, to make sure it can be run successfully. And then customize it to 4 sources. May refer to other config files for multiple sources.
