Hi, I’m looking for the following drivers for OEL 6.5:
infiniband-diags-1.5.13.MLNX*
infiniband-diags-guest-1.5.13.MLNX* (this is the one I’m not able to find anywhere)
Both for x86_64
Is there any way to obtain those RPMs?
Thanks in advance.
Both for x86_64
Thanks in advance.
Marc, thanks again for your reply (and for the drivers)
I will open a ticket with Oracle Support to check which is the required version for Oracle VM virtual servers
Leandro.
The required package version is not available for OEL 6.5.
The MOFED driver 2.1-1.0.0 was the first driver supported for OEL 6.5 and contains infiniband-diags* 1.6.2.
Which version of mofed did you install ?
What do you need a such version of theses specific packages ?
Waiting for your answers
Marc
Hi Leandro,
I attached the required RPMs, but by the way they are part of a package for OEL 6.1 not for 6.5.
It seems that the inbox drivers of 6.5 are the same.
Marc
Hi Marc,
sorry for the delay in my reply.
I did not install any MOFED version, I am installing an OEL 6.5 Oracle VM image, and by default it comes with Infiniband-diags and infiniband-diags-guest 1.5.13
When I updated to OEL6.9, by mistake I updated those drivers to version 1.6 too. I was supposed to exclude those packages from the upgrade procedure.
So, now I’m trying to downgrade 1.6 drivers to the version that was originally installed on my VMs.
Thanks again.
Leandro.
