type : CX516A
OS : CentOS 7.6
I have the following configuration and I want to set the MTU value of IB to 65520 but it is not updated.
CONNECTED_MODE described in ifcfg-ib0 is set to YES.
/etc/sysconfig/network-scripts/ifcfg-ib0
CONNECTED_MODE=yes
TYPE=InfiniBand
MTU=65520
PROXY_METHOD=none
BROWSER_ONLY=no
BOOTPROTO=static
IPADDR=
PREFIX=24
DEFROUTE=yes
IPV4_FAILURE_FATAL=no
IPV6INIT=yes
IPV6_AUTOCONF=yes
IPV6_DEFROUTE=yes
IPV6_FAILURE_FATAL=no
IPV6_ADDR_GEN_MODE=stable-privacy
NAME=ib0
UUID=b1f0e139-55a4-4df3-b860-78806d60c84d
DEVICE=ib0
ONBOOT=yes
openibd opensmd service is enabled.
When the ibstat command is executed, port1 is displayed as two.
ibstat
CA ‘mlx5_0’
CA type: MT4119
Number of ports: 1
Firmware version: 16.33.1048
Hardware version: 0
Node GUID: 0x1070fd0300242dd0
System image GUID: 0x1070fd0300242dd0
Port 1:
State: Down
Physical state: Disabled
Rate: 40
Base lid: 0
LMC: 0
SM lid: 0
Capability mask: 0x00010000
Port GUID: 0x1270fdfffe242dd0
Link layer: Ethernet
CA ‘mlx5_1’
CA type: MT4119
Number of ports: 1
Hardware version: 0
Node GUID: 0x1070fd0300242dd1
Port 1:
State: Down
Rate: 10
Base lid: 65535
LMC: 0
SM lid: 0
Capability mask: 0xa651e84a
Port GUID: 0x1070fd0300242dd1
Link layer: InfiniBand
The IP address can be set, but the MTU value cannot be changed and remains “4092”.
ifconfig
eno1: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet <> netmask <> broadcast <>
inet6 fe80::6d9:f5ff:febc:6e26 prefixlen 64 scopeid 0x20
ether 04:d9:f5:bc:6e:26 txqueuelen 1000 (Ethernet)
RX packets 24239 bytes 1982868 (1.8 MiB)
RX errors 0 dropped 1448 overruns 0 frame 0
TX packets 32145 bytes 38036388 (36.2 MiB)
TX errors 0 dropped 0 overruns 0 carrier 0 collisions 0
device memory 0x90120000-9013ffff
enp24s0f0: flags=4099<UP,BROADCAST,MULTICAST> mtu 1500
ether 10:70:fd:24:2d:d0 txqueuelen 1000 (Ethernet)
RX packets 0 bytes 0 (0.0 B)
RX errors 0 dropped 0 overruns 0 frame 0
TX packets 0 bytes 0 (0.0 B)
ib0: flags=4099<UP,BROADCAST,MULTICAST> mtu 4092
Infiniband hardware address can be incorrect! Please read BUGS section in ifconfig(8).
infiniband 00:00:0A:77:FE:80:00:00:00:00:00:00:00:00:00:00:00:00:00:00 txqueuelen 256 (InfiniBand)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10
loop txqueuelen 1000 (Local Loopback)
RX packets 52 bytes 4311 (4.2 KiB)
TX packets 52 bytes 4311 (4.2 KiB)
Can you tell us if there are other setting points?
Regards,
Chikara.
