I am working on Jetson TK1,L4T version is R21.3. I open the kernel config CONFIG_DETECT_HUNG_TASK for debuging my custom driver module. Because the system would hung up when i runing app with my driver.
But after i booting the new compiled kernel, i get errors before i do anything(insmod my driver or start some app):
ubuntu@tegra-ubuntu:~$ [ 200.056259] INFO: task nvmap-bz:45 blocked for more than 80 seconds.
[ 200.062879] "echo 0 > /proc/sys/kernel/hung_task_timeout_secs" disables this message.
[ 200.070880] nvmap-bz D c08b49c0 0 45 2 0x00000000
[ 200.077899] [<c08b49c0>] (__schedule+0x3c4/0x764) from [<c009b334>] (kthread+0xbc/0xe4)
[ 200.086239] [<c009b334>] (kthread+0xbc/0xe4) from [<c000f358>] (ret_from_fork+0x14/0x20)
[ 200.100313] Backtrace for cpu 0 (current):
[ 200.104986] CPU: 0 PID: 48 Comm: khungtaskd Not tainted 3.10.40-gd93729d-dirty #3
[ 200.113029] [<c001723c>] (unwind_backtrace+0x0/0x140) from [<c00136f4>] (show_stack+0x18/0x1c)
[ 200.122066] [<c00136f4>] (show_stack+0x18/0x1c) from [<c0015f0c>] (smp_send_all_cpu_backtrace+0x78/0xf4)
[ 200.132343] [<c0015f0c>] (smp_send_all_cpu_backtrace+0x78/0xf4) from [<c00e55d0>] (check_hung_uninterruptible_tasks+0x33c/0x354)
[ 200.144628] [<c00e55d0>] (check_hung_uninterruptible_tasks+0x33c/0x354) from [<c00e563c>] (watchdog+0x54/0x58)
[ 200.155401] [<c00e563c>] (watchdog+0x54/0x58) from [<c009b358>] (kthread+0xe0/0xe4)
[ 200.163379] [<c009b358>] (kthread+0xe0/0xe4) from [<c000f358>] (ret_from_fork+0x14/0x20)
[ 200.173732]
[ 200.173732] sending IPI to all other CPUs:
[ 200.180001] Kernel panic - not syncing: hung_task: blocked tasks
[ 200.186011] CPU: 0 PID: 48 Comm: khungtaskd Not tainted 3.10.40-gd93729d-dirty #3
[ 200.193532] [<c001723c>] (unwind_backtrace+0x0/0x140) from [<c00136f4>] (show_stack+0x18/0x1c)
[ 200.202151] [<c00136f4>] (show_stack+0x18/0x1c) from [<c08b2120>] (panic+0xa0/0x20c)
[ 200.209904] [<c08b2120>] (panic+0xa0/0x20c) from [<c00e55dc>] (check_hung_uninterruptible_tasks+0x348/0x354)
[ 200.219723] [<c00e55dc>] (check_hung_uninterruptible_tasks+0x348/0x354) from [<c00e563c>] (watchdog+0x54/0x58)
[ 200.229718] [<c00e563c>] (watchdog+0x54/0x58) from [<c009b358>] (kthread+0xe0/0xe4)
[ 200.237387] [<c009b358>] (kthread+0xe0/0xe4) from [<c000f358>] (ret_from_fork+0x14/0x20)
Then, i found the nvmap-bz task and disable CONFIG_TEGRA_NVMAP. After that, my driver works fine.
Is there a bug in the nvmap?
