Information about iio:device0 ui_input_{0..2} (t210)
Is there some documentation about the meaning of ui_input_{0…2}, e.g. cat /sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0/ui_input_* values? (Thx)
Hi beyondTime,
Please refer to the following instruction for the sysfs node of INA3221.
NVIDIA Jetson Linux Developer Guide : Clock Frequency and Power Management | NVIDIA Docs
Thanks for the reference to power management node explanation for various Jetson boards. It mentions (almost) all nodes, including a short description, but ‘ui_input’ node is missing on that documentation page.
If it’s a kernel module related output (from ina3221 hw monitoring ic), there should be a reference within source code or header file for a driver.
# ls -al /sys/bus/i2c/drivers/ina3221x/6-0040/iio:device0
total 0
drwxr-xr-x 3 root root    0 déc.  27 02:32 .
drwxr-xr-x 4 root root    0 déc.  27 02:32 ..
-rw------- 1 root root 4096 déc.  27 02:32 crit_current_limit_0
-rw------- 1 root root 4096 déc.  27 02:32 crit_current_limit_1
-rw------- 1 root root 4096 déc.  27 02:32 crit_current_limit_2
-rw------- 1 root root 4096 déc.  27 02:32 crit_current_limit_sum
-rw------- 1 root root 4096 déc.  27 02:32 crit_power_limit_0
-rw------- 1 root root 4096 déc.  27 02:32 crit_power_limit_1
-rw------- 1 root root 4096 déc.  27 02:32 crit_power_limit_2
-r--r--r-- 1 root root 4096 déc.  27 02:32 dev
-rw------- 1 root root 4096 déc.  27 02:32 in_current0_input
-rw------- 1 root root 4096 déc.  27 02:32 in_current0_trigger_input
-rw------- 1 root root 4096 déc.  27 02:32 in_current1_input
-rw------- 1 root root 4096 déc.  27 02:32 in_current1_trigger_input
-rw------- 1 root root 4096 déc.  27 02:32 in_current2_input
-rw------- 1 root root 4096 déc.  27 02:32 in_current2_trigger_input
-rw------- 1 root root 4096 déc.  27 02:32 in_current_sum_input
-rw------- 1 root root 4096 déc.  27 02:32 in_power0_input
-rw------- 1 root root 4096 déc.  27 02:32 in_power0_trigger_input
-rw------- 1 root root 4096 déc.  27 02:32 in_power1_input
-rw------- 1 root root 4096 déc.  27 02:32 in_power1_trigger_input
-rw------- 1 root root 4096 déc.  27 02:32 in_power2_input
-rw------- 1 root root 4096 déc.  27 02:32 in_power2_trigger_input
-rw------- 1 root root 4096 déc.  27 02:32 in_voltage0_input
-rw------- 1 root root 4096 déc.  27 02:32 in_voltage1_input
-rw------- 1 root root 4096 déc.  27 02:32 in_voltage2_input
-r--r--r-- 1 root root 4096 déc.  27 02:32 name
lrwxrwxrwx 1 root root    0 déc.  27 02:32 of_node -> ../../../../../../firmware/devicetree/base/host1x/i2c@546c0000/ina3221x@40
-rw------- 1 root root 4096 déc.  27 02:32 polling_delay_0
-rw------- 1 root root 4096 déc.  27 02:32 polling_delay_1
-rw------- 1 root root 4096 déc.  27 02:32 polling_delay_2
drwxr-xr-x 2 root root    0 déc.  27 02:32 power
-rw------- 1 root root 4096 déc.  27 02:32 rail_name_0
-rw------- 1 root root 4096 déc.  27 02:32 rail_name_1
-rw------- 1 root root 4096 déc.  27 02:32 rail_name_2
-rw------- 1 root root 4096 déc.  27 02:32 running_mode
lrwxrwxrwx 1 root root    0 déc.  27 02:32 subsystem -> ../../../../../../bus/iio
-rw-r--r-- 1 root root 4096 déc.  27 02:32 uevent
-rw------- 1 root root 4096 déc.  27 02:32 ui_input_0
-rw------- 1 root root 4096 déc.  27 02:32 ui_input_1
-rw------- 1 root root 4096 déc.  27 02:32 ui_input_2
-rw------- 1 root root 4096 déc.  27 02:32 warn_current_limit_0
-rw------- 1 root root 4096 déc.  27 02:32 warn_current_limit_1
-rw------- 1 root root 4096 déc.  27 02:32 warn_current_limit_2
They(ui_input_x) are just the voltage and current for different channel(x) and you could find more details in ina230.c.
Thank you for explaining and the source reference.
