I am having some troube in using my Makefile to compile my progam and to give me information on all of the loops that are parallelizable and those that are not.
I am seeking output like:
main:
24, Generating copyout(r[0:n-1])
Generating copyin(a[0:n-1])
Generating compute capability 1.0 binary
Generating compute capability 2.0 binary
26, Loop is parallelizable
Accelerator kernel generated
26, #pragma acc for parallel, vector(256) /* blockIdx.x threadIdx.x */
CC 1.0 : 3 registers; 48 shared, 4 constant, 0 local memory bytes
CC 2.0 : 10 registers; 4 shared, 60 constant, 0 local memory bytes
but what I am gettng is:
ray_sgm2.c:130: warning: ignoring #pragma acc region
ray_sgm2.c:692: warning: ignoring #pragma acc region
ray_sgm2.c:707: warning: ignoring #pragma acc region
ray_sgm2.c:760: warning: ignoring #pragma acc region
Now I understand that I know it can ignore a loop if it is not paraeleizable, but it should at least give me a reason instead of just saying ignoring it. The example is the first section of output vs. the second section show the contrast.
Now please undertand that these output files came from dfferent sets of code. Thus they will be different in their output. However, I just want more info than what I am getting.
I believe the key is the command line option Minfo. But what do I do with it?
My makefile is
CC=gcc
CFLAGS=-c -Wall -O0 -Minfo=ccff -Mprof=lines
LDFLAGS= -lm -lrt
SOURCES= main.c WEGprint.c InitializeScenarioData.c WAFmutex.c P_tra_ray2.c thread.c P_prc_typ2.c set_nod2.c env_nodb.c vlm_atnb.c tra_ray2.c zro_rng2.c lin_lin.c test_vlm_atn3.c prc_typ2.c ray_sgm2.c vlm_atn3.c ray_typ2.c test_ndx_tbl.c str_eig.c zsbl94.c snd_slw2.c ndx_tbl.c btm_dptb.c lwr_vtx2.c rfl_srf2.c rfl_btm2.c zbtms94.c zbtmrf9.c vrt_typ2.c dcm_sgm2.c vrt_tim2.c prc_ray2.c vrt_srf2.c srf_int2.c vrt_btm2.c btm_int2.c vrt_ray2.c gnr_seq.c chn_rfl2.c unfold2.c int_bnd2.c nrm_bnd2.c zblos94.c zbtmr04.c zsigmpr.c zsigmpv.c trn_mtx2.c adv_mtx2.c zelblos.c zbrlael.c WAFmathComplex.c zgsiz2des.c zgam.c zbeta.c WEG.c src_ang2.c prc_brn2.c merge.c IntSrcRays.c
OBJECTS=$(SOURCES:.c=.o)
EXECUTABLE=grab_64
all: $(SOURCES) $(EXECUTABLE)
$(EXECUTABLE): $(OBJECTS)
$(CC) $(LDFLAGS) $(OBJECTS) -o $@
.c.o:
$(CC) $(CFLAGS) $< -o $@
I do not know what i did to get such a lean uninformational output.
Any help appreciated. Thanks in advance.
Newport_j
