• Hardware Platform : dGPU • DeepStream Version : 6.0.1 • NVIDIA GPU Driver Version : 510.85.02 • Issue Type : Questions
When I try to use Deepstream for inferencing on video , the initial few seconds of the video is missing in the output. I get the inferenced output after 15th second of video as first frame. The video has 30 FPS. That means 450 (15 * 30) frames are missing. Can you tell me how to solve this issue? What Changes I have to in the pipeline?
I am using source pipeline and main pipeline. Can you tell me from your perspective which element in the pipeline should be causing the output inference to start after 15 seconds and missing the initial few seconds video.
I’m not completely sure. Cause in our demo, we have not encountered similar problems. And we cannot use interpipe in our env. So we hope you can use our plug-in or the native plug-in of gstreamer to repro this problem.
I am getting the 15 seconds of video missing in the inference output. And the output video starting after 15 sec. These 15 sec frames are missing from my output. And Nvidia forum is suggesting it is due to interpipe used to connect different the pipeline. I have 3 pipelines source , dummy, main pipeline. Source pipeline is switched to Dummy when camera stream is not working to provide blank frames. Please Help me in this issue. I am attaching my pipeline graph .
If Solano don’t have feedback temporarily, you can do a inatial analysis yourself by the following:
Add the probe function to each plugin and check which plug-in dropped data.
You can refer to our source code to add the probe function:
