Initialization bug
The following program shows an initialization bug which occurs in the current version
of the compiler.
module lib
  implicit none
  type :: A
     integer :: iA = -1
  end type A
  type (A), dimension (0:2), save :: Abox
contains
  subroutine init_A ()
    Abox(1)%iA = 1
  end subroutine init_A
end module lib
program test
  use lib
  implicit none
  call init_A ()
  print *, Abox(0)%iA
!! ERROR Should be -1 instead of 0
end program test
Furthermore, if we omit save attribute in the definition of Abox and break the F95 standard in this way - the program compiles without error even though the option -Mstandard is used.
Regards,
James
Hi Jamie,
It looks like a bug in the 6.1 compiler since it works as expected with 6.0. I’ve added a technical problem report (TPR #3840) and hopefully we can get this issue resolved quickly.
Thanks for the report,
Mat
