Initialize OP-TEE with modified fixed vector
I have a question about how I can create my own FV for use with OP-TEE.
According to the example in the Tool for EKB generation about the fv_ekb_t234:
This is the fixed vector for deriving EKB root key from fuse.
It is expected user to replace the FV below with a user specific
FV, and code the exact same user specific FV into OP-TEE
It is the last part here I can’t seem to find any information on. I’m guessing I have to supply the FV to the hwkey-agent during build of OP-TEE somehow, but I have never build OP-TEE before and I don’t know where to start looking for changing out the FV.
Could someone please point me in the right direction?
Best regards,
Baard
Hi baard.krohg,
Please refer to atf_and_optee_README.txt for details.
Hello Kevin!
For now I’m using a devkit, but I’ll eventually use a custom board. Does that change things? I’m using R35.4.1
The README is enough to get me started I think, but on the first read through I didn’t see anything about the FV?
A little update;
I was able to build optee and flash it to my devkit (I think). Because it won’t boot. I’m getting a kernel panic because it can’t decrypt the drive, which is (I’m guessing) because optee didn’t encode the correct FV when it was built.
Bootlog captured from minicom:
bootlog.txt (87.9 KB)
Since I didn’t know any better I just generated the ekb with a random FV, and hoped the hwkey-agent would pick up the fv_ekb_t234 file and incorporate it somehow when I built the system. I replaced the tos-optee_t234.img file in the BSP with the generated tos.img file as per the instructions in the readme. I then flashed the devkit, (btw, I had to re-install python3-cryptography after having uninstalled it to be able to compile optee) and the result is the boot-log above.
I haven’t really looked through the flash-log because I don’t know what to look for there (if anything)
flash_1-5_0_20230823-153030.log (39.5 KB)
For reference, the flash commands I’m using are below, and work if I only use the standard FV:
sudo ./apply_binaries.sh
sudo ./tools/l4t_create_default_user.sh -u $USERNAME -p $PASSWORD --accept-license
sudo systemctl stop udisks2.service
sudo ./tools/kernel_flash/l4t_initrd_flash.sh \
     --showlogs --no-flash \
     -p "-c bootloader/t186ref/cfg/flash_t234_qspi.xml" \
     --network usb0 \
     jetson-agx-orin-devkit internal
sudo ROOTFS_ENC=1 ./tools/kernel_flash/l4t_initrd_flash.sh \
     --showlogs --no-flash --external-only --append \
     --external-device nvme0n1p1 \
     --network usb0 \
     -i ./sym2_t234.key \
     -c ./tools/kernel_flash/flash_l4t_t234_nvme_rootfs_enc.xml \
     jetson-agx-orin-devkit external
sudo ./tools/kernel_flash/l4t_initrd_flash.sh --showlogs --network usb0 --flash-only
Edit:
So, my question remains- how do I properly supply the FV to optee when building it?
Or do I also have to “preemptively” copy the files from .../optee/install/t234/... to the system by copying them into the Linux_for_Tegra/rootfs/...?
I think I found it-
When changing out the FV as you generate an ekb, you also have to change out the
static unit8_t fv_for_ekb[] = {...}
in optee/optee_os/core/pta/tegra/jetson_user_key_pta.c, and compile it according to the readme instructions mentioned earlier.
I also copied the resulting install files to the Linux_for_Tegra/rootfs before flashing, but I’m not sure whether or not this was necessary.
hello baard.krohg,
please access to jetson-linux-r3541 to download the [Driver Package (BSP) Sources].
as you can see… there’s t234 example to generate EKS image, it’s using a test key as FV key by default.
for example, $public_sources/r35.4.1/Linux_for_Tegra/source/public/atf_and_optee/optee/samples/hwkey-agent/host/tool/gen_ekb/example.sh.
you may refer to KDF of Fuse Keys section to replace that key with generated fixed vector (FV), or the user-defined key by running the openssl tool from the command line.
then,
you may running gen_ekb.py to create a new EKS image, and flashing to the target.
besides,
as you mentioned, please update the keys within fv_for_ekb to match the ‘fv’ vector used for EKB binary.
please see-also Topic 246326. thanks
