I am working on jetson TX2, and I am using a Gige Camera.
I didn’t find a way to copy directly the image in unified memory (I can use pinned memory too). Is there a solution to do that ?
The pointer is not declare in unified memory, I don’t control the adress of the image provides by the camera. I have to initialize the image stocked in unified memory with a for-loop, and it takes a long time.
Thank you for your help
