'initializing nvenc contex' error when run on V100
• Hardware Platform (Jetson / GPU) GPU(V100)
• DeepStream Version 7.0
• TensorRT Version 8.6
• NVIDIA GPU Driver Version (valid for GPU only) 535.161.08
• Issue Type( questions, new requirements, bugs) questions
I create a images and then run it success by docker.
But when I run this image by Kubernetes, an error occured.
The log is as mentioned below.
Could you give me a hint?
Thank you.
If it works fine in docker,you can refer to this post on stackoverflow.
Thank you for replying.
In my case, I set ’ NVIDIA_DRIVER_CAPABILITIES as all and the issue solved.
