Inkling 2 Mini
Some numbers from one Spark, running the stock vLLM recipe. They line up with @jameslacroix’s.
Setup: vllm/vllm-openai:nightly (0.34.0rc1.dev1163) with the recipe’s dgx_spark_gb10 config: TP1, --max-model-len 262144, --reasoning-parser inkling, DSpark with 7 draft tokens. The only change was --gpu-memory-utilization 0.5, which still leaves 632,959 tokens of KV cache, nowhere near binding here. Default sampling (temp 1.0). vllm bench serve through the chat endpoint, client on the same box, ~1.2k tokens in and 1,024 out per request (reasoning included).
1 request 16 concurrent
SPEED-Bench throughput_1k, output tok/s 49.6 198.1
Per request, from TPOT ~50 mean, ~60 median ~14
TTFT median / P99 161 ms / 213 ms 2.9 s / 10.7 s
DSpark acceptance (tokens per step) 28.9% (3.0) 27.7% (2.9)
Random tokens, output tok/s 36.4 174.6
Random tokens, acceptance (tokens per step) 16.6% (2.2) 15.5% (2.1)
  1. The prompt set moves the single-stream number by about a third. On random tokens I get 36.4 tok/s, close to @hiroshiya’s tg1024. On SPEED-Bench it’s 49.6. I haven’t checked what llama-benchy sends, but if it’s synthetic text, the drafter will accept little and you’ll see this same gap.
  2. The 273 ÷ 5.4 ceiling applies to forward passes, not tokens. With ~3 tokens accepted per verify pass, median TPOT is 16.8 ms (~60 tok/s), already above it. That matches @jameslacroix’s 33 → 60 tok/s with DSpark.
  3. At 16 concurrent it’s ~14 tok/s per request, below @JW2026’s 30–40 per-stream bar, and the cost shows up in the first-token wait. I haven’t tried the concurrency levels in between.
Cold start was ~9 min: 3 to download, 2 to load, 3.5 for autotune and CUDA graphs. Not tested: long context, images, quality.
[disclosure: I helped the team at Enverge.ai run this test]
Preliminary results on Strata fork with Unsloth 3 bpw on old laptop Rtx A5000 mobile 15Gb vram ~ 50 Tok/s . This will be my break box (or run batch) in case of emergency
You hit the ram ceiling. C=16 is impractical on single GX10 or anything with DDR5 on TP=1
This is incredibly wrong.
I pull nearly 1k tokens per second aggregate out of Gemma4-26B-A4B all day, with batch processing workloads, C=64-192
If you haven’t pushed individual streams down to 5-10 tok/s alongside a model with well tuned MTP you haven’t actually reached the platform’s aggregate potential.
I configured llama-benchy to send Sherlock Holmes.
To my understanding, 273 ÷ 5.4 is the FP8 theoretical decode ceiling without a drafter, and considering that the majority of the model is in FP4, I expected the model to decode at well over 50 tok/s even with its drafter disabled.
Maybe Hyperflare’s DSpark implementation needs some work, but even if it can stably decode at around 60 tok/s, Qwen3.8-FN still seems a far better choice for a single spark in my opinion.
What can I say, I’m amazed and would be glad to be wrong. I prefer 35-50 tok/s at C=1-8 than 10 tok/s at C=64-192 , interactive vs batch, but to each his own. Again, Gemma 4 is not Inkling 2 Mini, so I’ll wait for you actual result.
How are you arriving at your concurrency limits? I do a lot of batch work with 27b and settled mostly on wall time per volume while still gunning for 15+ TPS per instance. Waves are dispatched such that prefill and decode line up well but I felt like it was diminishing returns going beyond a certain point.
First, benchmark. Llama-benchy is a nice framework but not ideal for MTP benching unless you feed it a better corpus, but even if you have nothing else, start there.
You will see continued rise with higher concurrency but it’s heavily dependent on the exact drafting system and model architecture. The best concurrent drafting is MTP, not dflash/DSpark or similar, and the best MTP implementation for concurrency is Gemma4’s.
Your task has to be amenable to it. Most users wouldn’t be happy with 5 tok/s but even if you don’t like it, that’s what optimal performance looks like. I do a lot of large batch processing of text, with scheme enforced structured output, so the aggregate is what matters and the JSON schema is highly amenable to drafters.
Finally, you have to actually saturate the endpoint. Not waves. Use a semaphore to hit a target concurrency and constantly post new queries as any are returned.
Gemma4-31b-it is optimal around c=16, 180-250 tok/s. 7 predicted tokens.
Gemm4-26b-a4b is optimal around c=128 but I’ve had it up to 256. ~1k tok/s. 3 predicted tokens.
Use FP8 quant for both. Apply FP8 tuning. 4-bit is not worth it as the drafters lose quality, and your throughout is overwhelmingly from the drafters.
Sorry for hijacking the thread, only because I was asked…
I agree about the Qwen3.8-FN choice. My benchmarks confirm this.
I didn’t see the potential in this model — it looks like a small model, but in practice it takes up an entire node to run, offers neither high speed nor heavy parallelism, and is limited by its “brain.” Who is it even competing with? Qwen38 27B? Qwen38 Flash Next? What’s its unique point beyond the user-facing side? A 1M context window? Fine, but I’d rather give that node to Qwen Flash than to it. In short: put it up out of the hype, took a look, and removed it.
I think it’s trying to compete with existing small-and-dense models, like Qwen3.8-27B and Gemma4-31B. It’s supposed to provide on-par intelligence at dramatically faster decoding throughput since it’s an MoE model. Native 1M context window is also a sweet bonus.
The problem is that the supposedly high throughput doesn’t exist, at least not yet. No matter if it’s on GB10, GB202, or Apple Silicon, it currently decodes only marginally faster than those dense models. It’s still a very early stage for Inkling-2-Mini, so things may change.
Qwen no longer provides a sub-50B MoE model, so I can see why people are so hyped about this model. They want a spiritual successor to the beloved Qwen3.6-35B-A3B.
It’s selling point seems to be “hey, I’m not a chinese model”. It’s suppose to be at MoE model with dense model brain/intelligence. I’ve not do any real test on it other than testing for speed. Just like Qwen 3.8 FN, there is probably a process of optimizations needed but maybe the focus is on the Inkling 2 small. Will wait for someone to fit it on 1 spark.
The point of small models from different families is that they can work together. For example, a small Qwen Bonzai can do the main work while a small Inkling acts as a reviewer. It will be slower, but the quality can be much better. Both can easily fit on a single Spark and produce excellent results.
hmm - it’s not small - that’s the problem. in reality - this little guy is a glutton. give it a window and give it parallelism and it takes over the entire node (while its speed for its size is modest, the number of parallel streams is modest, and its capabilities are limited by the total weight)
Are we talking about mini or small? If mini — it easily fits on a single node (but as mentioned above, it takes over that node entirely).
why “entirely”? It depends on how you configured it, e.g. two models with a sequential workflow, Bonsai is growing faster than Inkling:
probably I need to stop thinking of it as a MoE analog of Qwen3.6-35B-A3B and just put it on par with dense Qwen3.8 27B — then it becomes clear why there’s no speed and why it’s such a resource hog
Maybe the point with Inkling 2 mini is to be able to run it with discrete GPUs with little VRAM plus little system RAM and have decent speed, without having to quantize it to 1-2 bit? I see this as a much better candidate than 27B to be used in Strata or FreeToken for example. I don’t think it’s a model meant for Spark/Thor/M5…
Following up on the tool-eval-bench results above: we ran Inkling 2 Mini on
Athena-engine, our own inference engine, on a single DGX Spark (GB10), under the
same conditions as the vLLM run posted here.
Setup: tool-eval-bench v3.1.0, all 69 scenarios, temperature 0, seed 42, sequential,
120 s timeout, max 8 turns, thinking on. Weights: Unsloth Q8_0 for the dense parts,
original experts, with the DSpark drafter.
Result on Athena-engine: 90/100 (vs 87 in the vLLM run above), median turn 3.2 s,
21 minutes total.
Compared case by case with the vLLM run:
  • Failed in both: TC-58 (shows the fake API key from the injected “system message”)
    and TC-68 (calls tools under schema pressure).
  • Partial in both: TC-22, 43, 50, 57, 60, 62.
  • Passed by us, failed in the vLLM run: TC-13, TC-32, TC-51. TC-63 was partial for
    us (no reasoning loop this time).
  • Failed only by us: TC-44. Asked for the value of pi, the model recites digits in
    its reasoning, slips and loops until the cap. It’s the same greedy-loop behaviour
    as TC-63 above, just on a different case.
At temperature 1.0 (the authors’ recommended setting) our earlier Athena-engine runs
scored 81-83. Those used an older harness (2.3.1) with 4 parallel requests, so they
are not directly comparable. We are now repeating 1.0 (and 0.6) on v3.1.0 to
separate the effect of temperature, and we are looking at how to reduce the
reasoning loops. Happy to share the per-scenario JSON if useful.
+1 I think same here. Its the one that can natively (NVFP4) run on consumer GPUs and get job done at much faster speed.
