I could not find any information on inline PTX in the programming guide. Any quick reference? Where can I find more information?
There is a separate pdf in the toolkit call “Using inline PTX Assembly in CUDA”.
for some reason I cannot find any such pdf External Image
Which toolkit version are you using? The linux toolkit I have contains these pdfs:
cuda:~/Desktop/packages$ sh ./cudatoolkit_4.0.11_linux_64_ubuntu10.10.run --list | grep pdf
-rw-r--r-- buildmeister/buildmeister 677991 2011-02-21 18:46 ./doc/CUDA_Developer_Guide_for_Optimus_Platforms.pdf
-rw-r--r-- buildmeister/buildmeister 770005 2011-02-21 18:46 ./doc/CUDA_4.0_Readiness_Tech_Brief.pdf
-rw-r--r-- buildmeister/buildmeister 706554 2011-02-21 18:46 ./doc/nvcc.pdf
-rw-r--r-- buildmeister/buildmeister 5684406 2011-02-21 18:46 ./doc/CUDA_Toolkit_Reference_Manual.pdf
-rw-r--r-- buildmeister/buildmeister 2635531 2011-02-21 18:46 ./doc/ptx_isa_1.4.pdf
-rw-r--r-- buildmeister/buildmeister 936295 2011-02-21 18:46 ./doc/CUBLAS_Library.pdf
-rw-r--r-- buildmeister/buildmeister 385003 2011-02-21 18:46 ./doc/CUFFT_Library.pdf
-rw-r--r-- buildmeister/buildmeister 3742144 2011-02-21 18:46 ./doc/NPP_Library.pdf
-rw-r--r-- buildmeister/buildmeister 3195559 2011-02-21 18:46 ./doc/CUDA_C_Programming_Guide.pdf
-rw-r--r-- buildmeister/buildmeister 2147581 2011-02-21 18:46 ./doc/CUDA_C_Best_Practices_Guide.pdf
-rw-r--r-- buildmeister/buildmeister 255131 2011-02-21 18:46 ./doc/cuobjdump.pdf
-rw-r--r-- buildmeister/buildmeister 504350 2011-02-21 18:46 ./doc/cuda-memcheck.pdf
-rw-r--r-- buildmeister/buildmeister 296935 2011-02-21 18:46 ./doc/Fermi_Compatibility_Guide.pdf
-rw-r--r-- buildmeister/buildmeister 2994783 2011-02-21 18:46 ./doc/ptx_isa_2.3.pdf
-rw-r--r-- buildmeister/buildmeister 709981 2011-02-21 18:46 ./doc/OpenCL_Programming_Overview.pdf
-rw-r--r-- buildmeister/buildmeister 1474319 2011-02-21 18:46 ./doc/OpenCL_Programming_Guide.pdf
-rw-r--r-- buildmeister/buildmeister 560356 2011-02-21 18:46 ./doc/Thrust_Quick_Start_Guide.pdf
-rw-r--r-- buildmeister/buildmeister 801536 2011-02-21 18:46 ./doc/CUDA_VideoDecoder_Library.pdf
-rw-r--r-- buildmeister/buildmeister 1566476 2011-02-21 18:46 ./doc/OpenCL_Best_Practices_Guide.pdf
-rw-r--r-- buildmeister/buildmeister 556665 2011-02-21 18:46 ./doc/CUSPARSE_Library.pdf
-rw-r--r-- buildmeister/buildmeister 823390 2011-02-21 18:46 ./doc/CURAND_Library.pdf
-rw-r--r-- buildmeister/buildmeister 725019 2011-02-21 18:46 ./doc/cuda-gdb.pdf
-rw-r--r-- buildmeister/buildmeister 271259 2011-02-21 18:46 ./doc/Fermi_Tuning_Guide.pdf
-rw-r--r-- buildmeister/buildmeister 679267 2011-02-21 18:46 ./doc/OpenCL_Jumpstart_Guide.pdf
-rw-r--r-- buildmeister/buildmeister 245088 2011-02-21 18:46 ./doc/Using_Inline_PTX_Assembly_In_CUDA.pdf
-rw-r--r-- buildmeister/buildmeister 2962466 2011-02-21 18:46 ./computeprof/doc/Compute_Visual_Profiler_User_Guide.pdf
You can see the one you need near the bottom of the list.
thanks. Some problem with windows I guess. I reinstalled and now I can see the pdfs.
You can also find some example code in this [topic=194835]topic[/topic].
