Is there any way to use TensorRT with input images with dtype int8? E.g. send images with RGB values in range [0, 255] and do normalisation on the GPU. All samples I’ve seen use dtype float32.
In Tensorflow we can use cast but that layer doesn’t seem to be supported by TensorRT. The benefit of using int8 would be to reduce the size of the data being sent to the GPU/TensorRT.
