Hello All,
I am attempting to run CUDA 2.0 with Driver version x86-177.73-pkg1 on a OpenSuse 10.3 32 bit System. However I dont seem to be able to see the devices as shown below. I have changed from a 8800gtx to a 9600gx2, I reinstalled the drivers and ToolKit and sdk
When i do a ./deviceQuery
NVIDIA: could not open the device file /dev/nvidia2 (Input/output error).
There is no device supporting CUDA.
[codebox]
Device 0: “Device Emulation (CPU)”
Major revision number: 9999
Minor revision number: 9999
Total amount of global memory: 4294967295 bytes
Number of multiprocessors: 16
Number of cores: 128
Total amount of constant memory: 65536 bytes
Total amount of shared memory per block: 16384 bytes
Total number of registers available per block: 8192
Warp size: 1
Maximum number of threads per block: 512
Maximum sizes of each dimension of a block: 512 x 512 x 64
Maximum sizes of each dimension of a grid: 65535 x 65535 x 1
Maximum memory pitch: 262144 bytes
Texture alignment: 256 bytes
Clock rate: 1.35 GHz
Concurrent copy and execution: No
Test PASSED
[/codebox]
I used to have a similar problem previously when I used to run with a 8800GTX when some one told me to
do chmod 0666 /dev/nvidia* as root
I did the same this time too but no luck. However when I move back to the 8800gtx it seems to work fine.
I can can see my 9800gx2 as well when I can do a lspci | grep -i nvidia as well
[codebox]
00:00.0 Host bridge: nVidia Corporation Unknown device 0071 (rev c1)
00:00.1 RAM memory: nVidia Corporation Unknown device 007f (rev a1)
00:00.2 RAM memory: nVidia Corporation Unknown device 0075 (rev a1)
00:00.3 RAM memory: nVidia Corporation Unknown device 006f (rev a1)
00:00.4 RAM memory: nVidia Corporation Unknown device 00b4 (rev a1)
00:01.0 RAM memory: nVidia Corporation Unknown device 0076 (rev a1)
00:01.1 RAM memory: nVidia Corporation Unknown device 0078 (rev a1)
00:01.2 RAM memory: nVidia Corporation Unknown device 0079 (rev a1)
00:01.3 RAM memory: nVidia Corporation Unknown device 007a (rev a1)
00:01.4 RAM memory: nVidia Corporation Unknown device 007b (rev a1)
00:01.5 RAM memory: nVidia Corporation Unknown device 007c (rev a1)
00:01.6 RAM memory: nVidia Corporation Unknown device 007d (rev a1)
00:02.0 PCI bridge: nVidia Corporation Unknown device 007e (rev a2)
00:04.0 PCI bridge: nVidia Corporation Unknown device 007e (rev a2)
00:05.0 PCI bridge: nVidia Corporation Unknown device 007e (rev a2)
00:09.0 RAM memory: nVidia Corporation MCP55 Memory Controller (rev a2)
00:0a.0 ISA bridge: nVidia Corporation MCP55 LPC Bridge (rev a3)
00:0a.1 SMBus: nVidia Corporation MCP55 SMBus (rev a3)
00:0b.0 USB Controller: nVidia Corporation MCP55 USB Controller (rev a1)
00:0b.1 USB Controller: nVidia Corporation MCP55 USB Controller (rev a2)
00:0d.0 IDE interface: nVidia Corporation MCP55 IDE (rev a1)
00:0e.0 RAID bus controller: nVidia Corporation MCP55 SATA Controller (rev a3)
00:0e.1 RAID bus controller: nVidia Corporation MCP55 SATA Controller (rev a4)
00:0e.2 RAID bus controller: nVidia Corporation MCP55 SATA Controller (rev a5)
00:0f.0 PCI bridge: nVidia Corporation MCP55 PCI bridge (rev a2)
00:0f.1 Audio device: nVidia Corporation MCP55 High Definition Audio (rev a2)
00:13.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a3)
00:18.0 PCI bridge: nVidia Corporation MCP55 PCI Express bridge (rev a3)
01:00.0 VGA compatible controller: nVidia Corporation G70 [GeForce 7300 GT] (rev a1)
06:00.0 PCI bridge: nVidia Corporation PCI express bridge for Quadro Plex S4 / Tesla S870 / Tesla S1070 (rev a2)
07:00.0 PCI bridge: nVidia Corporation PCI express bridge for Quadro Plex S4 / Tesla S870 / Tesla S1070 (rev a2)
07:02.0 PCI bridge: nVidia Corporation PCI express bridge for Quadro Plex S4 / Tesla S870 / Tesla S1070 (rev a2)
08:00.0 3D controller: nVidia Corporation GeForce 9800 GX2 (rev a2)
09:00.0 VGA compatible controller: nVidia Corporation GeForce 9800 GX2 (rev a2)
[/codebox]
Any help would be really appreciated.
Just for the record, Another thing I noticed when I use the 9800gx2
[codebox]
pmistry@pino:~/NVIDIA_CUDA_SDK/bin/linux/release> nvidia-smi
Gpus found in probe:
Found Gpuid 0x1000
Found Gpuid 0x8000
Found Gpuid 0x9000
Attaching all probed Gpus…NVIDIA: could not open the device file /dev/nvidia2 (Input/output error).
Failed to attach gpu
Could not allocate resources!
[/codebox]
I know that the gx2 has two gpus on it, does the sli or how it’s setup matter?
Thanks,
Perhaad
