Xavier NX
• DeepStream Version
6.0
4…6.1
• TensorRT Version
8.2.1
questions
Hello !
I have a question concerning inference with a tensorrt optimized network.
I don’t understand how reducing the size of the input improves performance:
I trained a detecnet with tao toolkit on 1280x1280 images, I can run it at 80 FPS with deepstream. When I reduce the input resolution of the network to 640x640 I run at 200 FPS. When I increase the input size to 2000x2000 I drop to 20 FPS.
However, I don’t understand how Tensorrt can allow such a performance gain: the network is trained on a fixed image size, does Tensorrt add a scaling layer?
If it is not the case, how are the weights of the network adjusted to proceed to inference on images with a different resolution than the training resolution?
If it is the case, how to explain the performance gain, for the different sizes?
Thanks for your answer.
