I am working with Dynamic stream adding in T4, Whenever I run it with a single stream it doesn’t work but a new stream is added then all the streams work in the desired way, but again if a stream is removed and only One stream is left in the pipeline then it stops processing again (probe doesn’t produce metadata).
My initial guess: It is attaching to the pad probe but it is unable to receive data from decodebin. Cause it produces messages after few seconds and we can see a frozen frame on the rtsp output as well.
• DeepStream Version
• TensorRT Version
I was able to solve this issue, In streammux property I was using batch size as total_number or max number of streams. I changed it to 1 and it worked.
